Old 10-13-2017, 05:23 PM   #1
LegendaryLW200
LegendaryLW200 has a spectacular aura aboutLegendaryLW200 has a spectacular aura aboutLegendaryLW200 has a spectacular aura about
1993 SL1
1994 SC2
Default Cradle (SUbframe) Swap Issues- 1993 SL1 and 1994 SC2
So my newly acquired 93 SL1 is mint all around minus a very crusty cradle... have done these swaps before so no issues all around from the tricky LCA bolts to working the crusty cradle out.
But after taking out the 93's cradle I noticed something different, the 93 has its transmission dog bone mounted to the cradle(not the vehicle frame itself) and the subframe from my 94 sc2 has the transmission dog bone mounted to the vehicle frame.
In a tight spot now, want to get this thing on the road... do I
a)weld on the bracket from my crusty 93 sl1 to the 94 subframe? (anyone done it before lol? it has one 15mm bolt and a tack welded bolt as well)
b) Somehow a way to add said transmission dog bone that mounts to the vehicle frame?
c) track down a very rare (so pretty much have to buy) a 91-93 sl or sc which in Canada is not as easy as
Any advice is a huge help guys, most subframe info online is just about the rad change. Not many that mention the tranny dogbone mount moving from cradle to frame!
Cheers
LegendaryLW200 is offline   Reply With Quote
Old 10-14-2017, 12:11 AM   #2
Default Re: Cradle (SUbframe) Swap Issues- 1993 SL1 and 1994 SC2
I don't remember that part being an issue with any of my radiator switcharoo's lol
Pretty sure it's riveted on...drill through it on the '93 cradle, make a mount hole on the '94 cradle and drop a grade 8 bolt through it to hold it in place (with accompanying washers).
Tags
91-93, cradle, dogbone, subframe
subframe/cradle quantumech S-Series Tech 2 11-05-2010 01:00 PM
SL engine swap from 1993 to 1994 came up with some proplems lazerbeak S-Series General 3 08-13-2010 03:37 PM
saturn cradle/ subframe help daveisdiving S-Series Tech 8 06-03-2009 11:45 AM
engine cradle / subframe swap information Hiddenlites S-Series Tech 6 06-20-2007 12:46 PM
Bent subframe (cradle?) Bent_SL2 S-Series Tech 18 08-05-2004 01:25 PM
