Old 12-19-2011, 11:54 PM   #1
sdeltoro93
sdeltoro93 is on a distinguished road
1996 SL1
Dizzy 3 Codes.. Throttle Position Sensor, both oxygen sensors no activity ? ???
So my engine light came on jad it scanned and it.said throttle position sensor, and both oxygen sensors have no activity? ?? Is this an electical problem or is it the throttle position sensor setting the oxygen sensors off??? Help plz
Add to sdeltoro93's Reputation
Rate the quality of this post and help sdeltoro93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdeltoro93 is offline   Reply With Quote
Old 12-20-2011, 04:53 AM   #2
Default Re: 3 Codes.. Throttle Position Sensor, both oxygen sensors no activity ? ???
None of the above. New member? With no background car info on any maintenance done, start from the beginning with these suggestions first; replace the coolant sensor if its the round nosed plastic one with a flat nosed brass one and replace the old thermostat with a new 195F one. These two items will fix many engine/transmission issues too numerous to list, including possible emissions testing halted with incorrect engine operating temperatures (the two O2 sensors not working).
If the throttle body hasn't been cleaned, remove it for disassembly of the tps and iacv for a thorough cleaning. Search in the How-to library for these tips.
Old 12-20-2011, 10:36 AM   #3
sdeltoro93
1996 SL1
I Have replaced the thermostat last week. Ill get one of the ects sensors today. But why wouldnt the o2 sensors work??
Old 12-20-2011, 11:15 AM   #4
Get the codes. The descriptions are interpreted to sell you parts.
Add to madpogue's Reputation
Old 12-20-2011, 11:22 AM   #5
On the back of the block, underneath the #4 cylinder intake runner and above the starter there is a 10mm bolt with 4 wires underneath it. These are the PCM and sensor grounds. You can see these if you take off the plastic air intake and look under the throttle body/intake just around the corner on the back. Verify all 4 wires, 2 black and 2 tan wires are attached and the ring terminals and block surface are clean. Do not drop the bolt as it will lodge behind the starter. Also verify that the TPS wiring is all connected.
Get the actual code numbers also....
Throttle Position Sensor? lgates3522 Vue Tech 26 05-27-2017 02:29 PM
Throttle Position Sensor mommybayer Relay Tech 0 12-11-2009 05:05 PM
throttle position sensor briansc1 S-Series Tech 7 08-04-2008 05:42 AM
Throttle Position Sensor saturncrzy S-Series Tech 6 05-15-2008 05:29 PM
Throttle Position Sensor sven1 L-Series General 0 05-31-2006 08:54 AM
