Old 01-05-2012, 01:09 PM   #1
sdeltoro93
sdeltoro93 is on a distinguished road
1996 SL1
Dizzy 3 Codes.. Throttle Position Sensor, both oxygen sensors no activity ? ???
So my engine light came on about a moth ago so i finallu scanned it yesterday and these 3 codes came up. P0140 02 sensor circuit no activity detected. Bank 1 sensor 2....... P0122 throtle position sensor ..... P0134 o2 sensor circuit no activity detected bank 1 sensor 1.
Could this be an electral problem? Or could they all just be bad?
Add to sdeltoro93's Reputation
Rate the quality of this post and help sdeltoro93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdeltoro93 is offline   Reply With Quote
Old 01-05-2012, 05:52 PM   #2
Cheyne
Cheyne will become famous soon enoughCheyne will become famous soon enough
2000 SL2
Default Re: 3 Codes.. Throttle Position Sensor, both oxygen sensors no activity ? ???
Yes and doubtful. Check the PCM & O2S ground on the backside of the engine above the starter.
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 01-05-2012, 07:03 PM   #3
sdeltoro93
1996 SL1
Where exacly are the grounds located i cant see aything because of the fuel rail?
Old 01-05-2012, 07:21 PM   #4
Cheyne
2000 SL2
You won't really be able to see them from the top. It's below the fuel rail and the intake manifold. If you feel with your hand, you should be able to feel the nut just below the driver's side of the intake manifold, backside of the engine (below the far driver's side of the cam cover if it helps you visually). You'll likely need to get the car up on ramps to see it from underneath. Tan tan/white black/white wires. Any chance you have a valve cover gasket that's leaking over there?
I can't scan a picture of the ground location at home. Let me know if you can't locate it, and I'll scan it tomorrow.
Old 01-23-2012, 09:41 PM   #5
sdeltoro93
1996 SL1
Ok so i looked today and still cant find them. Even if i do find them where are they even supposed to be grouned to?
Old 01-24-2012, 01:39 AM   #6
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
See the red dot in the picture. That would be your ground:http://www.saturnfans.com/forums/sho...8&postcount=10
Add to ehunter's Reputation
Rate the quality of this post and help ehunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ehunter is offline   Reply With Quote
3 Codes.. Throttle Position Sensor, both oxygen sensors no activity ? ??? sdeltoro93 S-Series Tech 4 12-20-2011 11:22 AM
Throttle Position Sensor mommybayer Relay Tech 0 12-11-2009 05:05 PM
Throttle Position Sensor saturncrzy S-Series Tech 6 05-15-2008 05:29 PM
Throttle Position Sensor? thewave46 S-Series General 3 12-11-2007 01:15 PM
Throttle Position Sensor sven1 L-Series General 0 05-31-2006 08:54 AM
