Old 10-03-2012, 03:00 PM   #41
schan2464
schan2464 is on a distinguished road
Default Re: MMO As Fuel Additive
I actually considered the fuel issue, but always understood that it was winter blend gas that would negatively affect fuel economy. I buy gas almost exclusively at Costco.
I put on 2 new tires fairly recently, and got the car aligned at that time. I doubt that new tires would negatively affect fuel economy this much.
Add to schan2464's Reputation
Rate the quality of this post and help schan2464 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
schan2464 is offline   Reply With Quote
Old 10-12-2012, 06:18 PM   #42
schan2464
Just wanted to post an update. Just after I filled up, I swapped out the oxygen sensor, and then a bit later, the air filter. The air filter had been changed 12,000 miles back, and didn't look all that dirty, but I figured it was worth a shot. I didn't know how to test the oxygen sensor, but again, in light of the fairly low cost of these items, it was cheap enough to just swap them out.
By the time I got around to filling up, my mileage was up to 26.7, so at least things look like they are moving in the right direction. I pumped up the tires to 35 psi all around, and look forward to checking mileage again at the next fill up. Having paid $4.539 for gas this past time (and I shopped around!), I'm hopeful that maybe the oxygen sensor was just getting lazy, but not bad enough to trigger a code.
Rps fuel additive EXCALIBER12 S-Series Tech 3 05-23-2010 09:50 PM
Bad Injector replace or run fuel additive nmsaty S-Series General 3 04-20-2006 11:25 AM
Fuel Additive? theguest59 S-Series General 27 10-01-2005 03:06 PM
Using Acetone as a Fuel Additive Luke S-Series Tech 83 08-04-2005 12:20 AM
Fuel/injector additive AmericanMade94 S-Series Tech 7 08-19-2004 08:47 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
