Old 12-06-2011, 09:00 AM   #1
lastcall190
lastcall190 is on a distinguished road
Default Odd electrical issue...
'04 L300, 40k miles, Automatic, runs fine (sans the occasional wrench light...).
I notice that with the windows up and radio off/low, I can hear a strange feedback coming from the speakers that perfectly coincides with the engine RPM. It almost sounds like when my buddy muffed up his stereo install and had a bad ground. The dash has never been off the car, no wires have been messed with, so I'm not sure what it started to happen. Sadly I can't remember if it had happened in the past, or if it's just a case of finally noticing it. Any ideas? Thanks
-J
lastcall190 is offline   Reply With Quote
Old 12-06-2011, 10:53 AM   #2
Default Re: Odd electrical issue...
You may have to check the radio connections to be sure its grounded otherwise you may have to hunt down this rf noise. Have the alternator tested. Be sure the battery, battery cables, and connections are clean and free of any corrosion, especially the ground connections.
I had a faulty alternator once; I transmitted a whine along with voice on a CB radio years ago while in a caravan of cars. A co-worker heard my xmission and remarked that the noise was from my alternator. Sure enough I found one of the six diodes had failed and caused the rf noise. Although not likely to occur, its a possibility and difficult to test for as the alternator must be removed from the engine for bench testing. Store tests may reveal a faulty one. I checked mine by hand and was able to find a rebuild factory that had my diode pack. A few hours of work and my rebuilt alternator was good as new. I never heard any rf noise from my car radio.
Old 12-06-2011, 02:06 PM   #3
lastcall190
Great I will have a look. I was planning on having the alt/batt tested anyhow, seeing as the car is almost 8 years old and I'm certain they are original. Also having some funny issues with the lights dimming and really getting dark when I use the windows. Thanks for the input.
-J
Old 12-09-2011, 12:39 AM   #4
Jonnyferrari
Jonnyferrari is on a distinguished road
Jonnyferrari's Avatar
2000 L-Series 3.0L Sedan
-J
My battery is brand new (2 months old) and the same thing tends to happen with the dimming...One new thing that happened last night in the 20 degree weather: My day-time running lights didn't work until the car had warmed for about a minute...anyone able to explain this??
[Sold] 2000 Saturn LS2 premium package; 120k
Jonnyferrari is offline   Reply With Quote
Old 12-11-2011, 04:25 PM   #5
mattachuz
mattachuz is on a distinguished road
mattachuz's Avatar
did you accidentally have the parking break on for that minute not realizing it? dont know if you mean that the car sat in park while warming up with the P brake on or if you were driving around for 1 minute before the lights came on? toggle the headlights on and off, a messed up stalk switch can stop the DRL from coming on.
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Anahiem (disneyland): xxx
Tulare: o,(x-atleast 15)
Visalia: x
mattachuz is offline   Reply With Quote
Old 12-11-2011, 05:18 PM   #6
Jonnyferrari
My parking brake was engaged at the time, I was on a steep hill. The eventually went on but I don't get how a parking brake would shut them off..
Old 12-11-2011, 06:42 PM   #7
mattachuz
mattachuz's Avatar
well i can answer that one lol
Page 115 of the 2000 L series owners manual
Daytime running lamps
Daytime Running Lamps (DRL) can make it easier for others to see the front of your Saturn during the day. DRL can be helpful in many different driving conditions, but they can be especially helpful in the short periods after dawn and before sunset.
The high beam headlamps bill come on at half the normal brightness when:
* The ignition is on
* The headlight switch is off, and
* The parking brake is released
When you turn on your headlamps, the DRL will switch off and the exterior lights will come on.
When you turn off the headlamps, the exterior lamps will go out and the high beam headlamps will come on at half the normal brightness again. As with any vehicle you should turn on the regular headlamp system when you need it.
To idle your vehicle with the DRL off, set the parking brake. The DRL will stay off until you release the parking brake.
When the daytime running lamps are on, the DRL indicator (top left indicator on the cluster) in the instrument panel is illuminated.
So to answer your question jonny, the parking brake would have EVERYTHING to do with the DRL not coming on.
mi: 199,xxx
trips:
X = dest
O = ON way
home- Clovis, ca
Pismo Beach: xx
Morro Bay: oo
San Francisco: x
Los Angeles: ooo
Visalia: x
Electrical issue whitedog59 S-Series General 15 08-06-2011 07:49 PM
AC issue - Electrical help dsieme01 L-Series Tech 7 06-07-2010 11:03 PM
Electrical issue? audiomodder S-Series Tech 6 05-14-2009 08:49 AM
Electrical Issue blackeagle1 S-Series Tech 3 07-30-2006 03:02 PM
Electrical issue DeCaff2006 S-Series General 7 07-02-2006 04:17 PM
