Old 03-06-2007, 05:37 PM   #1
oakraiders24
oakraiders24 is on a distinguished road
Default Ignition Coils....
This might sound stupid, but how do you disconnect the ignition coils from their backing?
Add to oakraiders24's Reputation
Rate the quality of this post and help oakraiders24 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oakraiders24 is offline   Reply With Quote
Old 03-06-2007, 05:48 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Ignition Coils....
the backing is called ......the ignition module.......just pull the coils off
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-06-2007, 06:01 PM   #3
oakraiders24
Sorry, it is hot here, and my brain is not working right. I found how to take it off. Precisely, place a flathead screwdriver between the ignition coil and the ignition module, at the bottom, and GENTLY pry it off. Thanks though Rich. Question, if the paint on the outside bar is chipping off, does the coil need to be replaced?
Old 03-06-2007, 08:17 PM   #4
No. Well, it's _possible_ you could get spark jumping to that unpainted part of the coil body. Light it up at night, with as little ambient light as possible. If you see any spark jumping to the scratched-off part, throw some more paint on in.
Add to madpogue's Reputation
Old 03-06-2007, 09:22 PM   #5
wolfman
wolfman's Avatar
The paint is NOT an electrical insulator. It is there to prevent corrosion. What prompted you to suspect the coilpacks as a problem to begin with?
Add to wolfman's Reputation
Old 03-06-2007, 09:58 PM   #6
oakraiders24
It was on the list for possible suspects to my still pending hesitation problem. They didn't look too bad. I cleaned the coils up clean, liberally (sp) put dielectic (sp) grease, and re-installed. Didn't solve the problem. The only thing was the corner paint was chipped off and it looked rusted underneath.
Ignition Coils Steven62387 S-Series General 3 08-02-2006 01:40 AM
Ignition Coils Batman87 S-Series Tech 4 04-24-2006 09:46 PM
Ignition coils Aldiaz2331 Miscellaneous Tech 4 10-18-2003 10:49 PM
ignition coils wxmd Mods and Performance 11 08-26-2003 02:31 PM
new ignition coils robk Mods and Performance 4 02-21-2002 06:38 PM
