Old 02-18-2007, 01:54 PM   #1
RMracing125
RMracing125 is on a distinguished road
Dizzy coolant temp sensor or what???
OK TRY AND FOLLOW ME ON THIS. i have a 97 sc2 and the question is this
when i first start my car it kinda sputters to start. then a min of idle the car does not warm up acording to the coolant guage. but all the sudden the guage shoots up to about half way, the car also revs up about 700 or so. them shoots back down to the coldest it can go. but after dealing with it and having to go to work it finally warms up acording to the coolant guage and it acts fine... ive replaced the coolant temp sensor and fixed the problem for a week. do you think that i got a bad sensor or something. it was only 7 dollers and would be more than happy to spend again as long as it runs like normal.
Add to RMracing125's Reputation
Rate the quality of this post and help RMracing125 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RMracing125 is offline   Reply With Quote
Old 02-18-2007, 03:38 PM   #2
Default Re: coolant temp sensor or what???
Have you tried to follow the threads covering the engine coolant temperature sensor? Look in the How-to section.
Old 02-19-2007, 07:31 AM   #3
BarnOwl
BarnOwl's Avatar
Typically when the ECTS goes, it leaks on the connector and you get corrosion. That connector's almost impossible to clean. If your connectors the least bit green, you need to replace it. Those $7 after market sensors are good most of the time but, they do have a higher failure rate than the OEM sensors. So, if you suspect you got a dud, go ahead and replace it.
Add to BarnOwl's Reputation
Coolant temp sensor? 3500srw S-Series Tech 8 06-26-2008 11:45 PM
3.5 l coolant temp sensor DMVue Vue General 6 12-15-2007 09:17 AM
coolant temp sensor danbandMN S-Series Tech 1 11-24-2005 12:29 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
where is the coolant temp sensor buddyc S-Series Tech 2 08-06-2003 06:18 PM
