Old 12-14-2006, 02:59 PM   #1
'98GoldSL1
'98GoldSL1 is on a distinguished road
'98GoldSL1's Avatar
1998 SL1
Default Vacuum leaks found!
Well I took everyone's advice on the forum, I read TONS of posts and fixes and finally found what the hell is REALLY wrong with my car. I made a post about the high idle, etc... well its a vacuum leak.
I used carb cleaner everywhere, turns out its the throttle body gasket. I heard air being sucked in, and the idle changed a LOT, to the tune of ~300rpm. I then sprayed some in the idle air passage, it went down some more and things smoothed out. It runs a bit better now, idles at 850, SES light went off, but its still misfiring BAD.
What would be the proper idle for the car? I've seen many different numbers on here? Once again, thanks EVERYONE for all the suggestions, help and advice.
SL1 256,000kms and counting...
2001 Yellow SC2 comin out soon
Add to '98GoldSL1's Reputation
Rate the quality of this post and help '98GoldSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
'98GoldSL1 is offline   Reply With Quote
Old 12-14-2006, 06:50 PM   #2
erick295
erick295 is on a distinguished road
erick295's Avatar
Default Re: Vacuum leaks found!
I'll just tell you what mine does: it depends on engine temperature and what accessories I have running. If it's cold, 1000-1200 is normal. When it's warm, around 600-700. Turning the AC on causes it to idle about 100 RPM faster.
Add to erick295's Reputation
Rate the quality of this post and help erick295 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
erick295 is offline   Reply With Quote
Old 12-14-2006, 08:22 PM   #3
harsha
harsha is on a distinguished road
harsha's Avatar
2006
I believe it differs from manual to auto trans....
As far as I know...(on warm engine)
Manual: 700-750
Antomatic: 850-900.
Somebody correct me, if I'm wrong!!!
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 12-14-2006, 09:20 PM   #4
'98GoldSL1
'98GoldSL1's Avatar
1998 SL1
Thanks guys. I'll see what mine comes out as tomorrow.
Old 12-15-2006, 09:04 AM   #5
jdcart
jdcart is on a distinguished road
My 97 SC1 with manual idles, when warm, at 750.
Add to jdcart's Reputation
Rate the quality of this post and help jdcart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdcart is offline   Reply With Quote
Old 12-15-2006, 12:16 PM   #6
Luke
Luke's Avatar
On my 95SL2, the correct idle is 750 ( +/- 50 ) in gear [automatic]
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline   Reply With Quote
Old 12-15-2006, 12:17 PM   #7
'98GoldSL1
'98GoldSL1's Avatar
1998 SL1
Thanks Luke. Once again you help me out.
Leaks NJSATXR 2008 Vue 6 08-18-2009 02:39 PM
Rough Idle - Changed TPS, ECT, cleaned EGR, sprayed for vacuum leaks. travisj027 S-Series Tech 10 07-06-2009 06:48 PM
Leaks JKRIGSBY S-Series Tech 3 02-21-2009 09:59 PM
Vacuum leak found {PART?} grelms S-Series Tech 6 12-24-2007 11:07 AM
vacuum leaks, high idle Jeff P Miscellaneous Tech 4 04-25-2002 04:24 PM
