Old 09-25-2006, 08:19 PM   #1
Steven62387
Steven62387 is on a distinguished road
Steven62387's Avatar
Dizzy Spongy Brakes
Ok so i was goin down the interstate and had to slam on brakes like everyone in front of me to avoid some plastic paysets in the middle of the road. the tires skipped and then finally screeched. Well after this the brakes were no longer working correctly.
I decided to buy new calipers, pad, shoes, wheel cylinders and rotors. After all was replaced the brakes were spongy, so i bled and rebled again. The back drums were adjusted so tight they were dragging, so those were adjusted tonight. Along with stripping a stud and 2 lugnuts yippee. And to top it all off the brakes are STILL spongy, i dont know what it could be. If ANYONE has any advice...please let me know...this is getting very irratating. It could be the brake booster or master cylinder. i just dont know
Add to Steven62387's Reputation
Rate the quality of this post and help Steven62387 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steven62387 is offline   Reply With Quote
Old 09-25-2006, 08:24 PM   #2
PlasticCarsRock
PlasticCarsRock's Avatar
Default Re: Spongy Brakes
The only think I can think is that you had some air in the ABS system, and when the ABS activated, it let it into the rest of the system. You should probably have the brakes bleed by someone with the proper scan tool to reset the ABS (or something). You can't properly bleed the Saturn ABS brakes without a special tool.
If you don't have ABS, then this is irrelevant and I have no clue.
If you hold the pedal firmly, will it sink to the floor-if so, you have a leak somewhere, which could have been caused by a panic stop.
good luck
Old 09-25-2006, 08:33 PM   #3
Steven62387
nope, I dont have ABS on my car, and i dont think i have a leak anywhere, but there might be something caught in the lines. Is it a good idea to flush or bleed the entire system and put all new brake fluid?
Old 09-25-2006, 08:39 PM   #4
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
yes, put new fluid in there. Use a turkey baster to extract fluid from the reservoir. Then, refill with new fluid. Pump the brakes and have somebody crack open each bleeder until new fluid comes out. If you have to, vaccuum bleed them.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 09-25-2006, 10:08 PM   #5
Steven62387
ok, but how do you vacumm bleed them? cant i just crack open the bleeders and just continuesly pump the brakes to get it all out?
Old 09-26-2006, 06:35 AM   #6
BarnOwl
BarnOwl's Avatar
First off, you haven't bled the brakes properly yet. Here's what you don't appear to understand, so far. When you open the bleed screws, the flow can go two ways. Meaning you can suck air into the system as well as take air and fluid out. The proper way to bleed brakes w/o special tools is to have an assistant pump the brakes a few times to pressurize the system then hold the brake down. While they continue holding the brake, you loosen and tighten the bleeder screw quickly. You have to tighten the screw before all the pressure is relieved otherwise you pull air back into the system.
A vacumn bleeder can be found at any auto parts store. However, I think you'd be better off with some speed bleeders. They are available here. Many parts stores carry them as well. They are bleeder screws that only allow one way flow. So, then you can just pump them the way you envision.
Add to BarnOwl's Reputation
Old 09-27-2006, 02:19 PM   #7
Bluesideup
Bluesideup is on a distinguished road
I've used my Motive Power Bleeder on our Saturn. It is the easiest way to bleed brakes for sure. I still have problems with a spongy pedal, I'm not sure if it is caused by ballooning brake lines or not.
Have any of you replaced your brake lines with new rubber or stainless braided lines? I've heard that as the lines get old they expand and cause a spongy pedal.
Add to Bluesideup's Reputation
Rate the quality of this post and help Bluesideup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bluesideup is offline   Reply With Quote
Old 09-27-2006, 02:49 PM   #8
BarnOwl
BarnOwl's Avatar
Yes a pressure bleeder is another way to do it. You probably have ABS. If so, I'm afraid you'll have to put it in the shop to get the brake bled or replace the master cylinder.
Old 09-27-2006, 07:46 PM   #9
andy_95sl2
andy_95sl2's Avatar
there is a very big difference between a spongy pedal and a pedal with long traveling distance, but effective. My car has a long pedal travel, but still stops well. Not nearly as good as my mom's car, but still good.
Over time, the rubber lines can balloon, but they are built with threads inside the rubber so that does not happen. Stainless Steel braided brake lines will increase your brake pedal feel, and thats one thing on my x-mas list
Old 09-27-2006, 09:08 PM   #10
eRic 02sc2
eRic 02sc2's Avatar
How to Bleed Brakes - The Right Way
http://www.teamscr.com/brakes.html
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-27-2006, 10:30 PM   #11
softspot
softspot is on a distinguished road
1997 SL1
My daughter was driving my 94 sl1 had panick stop brake did same thing , found out that master cylinder was leaking , take mounting bolts off master cylinder at booster pull cylinlider away from booster if you see or have any brake fluid there you have blowan seal in master cylinder , i did and replaced master cylinder, re -bleed hole system my problem solve ,hpe this mite help.
Add to softspot's Reputation
Rate the quality of this post and help softspot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
softspot is offline   Reply With Quote
Old 09-28-2006, 08:13 AM   #12
Bluesideup
Thanks for the tip, I'll try to check that out soon. Our car is a very basic SL1 without ABS. The brakes just don't seem to be very effective at stopping, just like when I boiled the brake fluid on a different car at the track.
Old 09-28-2006, 10:23 AM   #13
alcimedes
alcimedes is on a distinguished road
Just a quick reminder. Wear gloves when you're working with brake fluid. That stuff is particularly nasty and is absorbed through bare skin.
Add to alcimedes's Reputation
Rate the quality of this post and help alcimedes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alcimedes is offline   Reply With Quote
Very spongy brakes on 04 Vue talonsaab Vue Tech 2 05-27-2009 05:49 PM
Spongy brakes allwxrider S-Series Tech 20 12-24-2007 11:36 AM
Brakes Really Spongy 94 SL2, did all the usual fixes, is this just "normal" Fricken eh! S-Series General 4 06-03-2006 01:43 PM
spongy brakes on 97 SL1 resolved jen1979 S-Series General 2 11-29-2005 06:42 PM
spongy breaks jen1979 S-Series General 17 11-10-2005 10:45 PM
