Old 08-01-2006, 10:01 PM   #1
Steven62387
Steven62387 is on a distinguished road
Steven62387's Avatar
Default Ignition Coils
On my 95 SL1, when i replaced my plug wires I noticed a hite corrosion on a few of the coil towers. I sanded them down therfore removing all corrosion, hen i checked today...more corrosion. I doubt the coils have ever been replaced so im thinking about replacing them, what affect will the corrosion have on how the car runs? with ne coils will the car run/operate more smoothly? -thanks
Add to Steven62387's Reputation
Rate the quality of this post and help Steven62387 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steven62387 is offline   Reply With Quote
Old 08-01-2006, 10:11 PM   #2
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
2002 L-Series 2.2L Sedan
Default Re: Ignition Coils
well i doubt the corosion is coming fromt he coils themself so y replace them?
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 08-01-2006, 11:09 PM   #3
redkees@msn.com
redkees@msn.com is on a distinguished road
redkees@msn.com's Avatar
2004 VUE 2.2L
2008 AURA XE
Gently sand coil tower tips with sandpaper until shiny...coat with dialectic grease. Sand bolts to coil packs. Clean by sanding any corosion off dis modules under coil packs.
Corosion leads to arcing of spark from /wires/ coil tower tips / coil pack bolts and dis modules. You'll get sluggish performance, hesitation and the engine
will miss.
Add to redkees@msn.com's Reputation
Rate the quality of this post and help redkees@msn.com reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redkees@msn.com is offline   Reply With Quote
Old 08-02-2006, 01:40 AM   #4
Remove the coil packs and ignition module, and thoroughly clean all the ground contact areas on the tranny, the ignition module and the coil packs. Visit wolfman's gallery for pics of what needs to be cleaned. Better ground contact MIGHT prevent further buildup on the coil towers.
Check the resistance between the towers of each coil pack. When they're clean, it should be between 7 and 10 K Ohms.
Add to madpogue's Reputation
Ignition Coils.... oakraiders24 S-Series Tech 5 03-06-2007 09:58 PM
Ignition Coils Batman87 S-Series Tech 4 04-24-2006 09:46 PM
Ignition coils Aldiaz2331 Miscellaneous Tech 4 10-18-2003 10:49 PM
ignition coils wxmd Mods and Performance 11 08-26-2003 02:31 PM
new ignition coils robk Mods and Performance 4 02-21-2002 06:38 PM
