Old 07-13-2006, 11:33 PM   #1
oogy
oogy is on a distinguished road
Default lower trans mount Q!
Can you cut off part of that screw for the lower transmission anchor? I felt the nut through the frame today and it obviously does not need to be that long. I am asking because I'm going to change it this weekend and I have an automatic, thus difficulties in raising the entire transmission to get it to pop out.. Is there any issue with taking a hack saw and chopping that little bit of extra screw off (of both the old to get it out and the new to get it in) if I run into problems?
Thanks!
Add to oogy's Reputation
Rate the quality of this post and help oogy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oogy is offline   Reply With Quote
Old 07-14-2006, 01:00 AM   #2
Default Re: lower trans mount Q!
Sounds like a lot more work than simply raising the tranny a bit. Why would it be more difficult with an automatic? You need to jack the tranny to support it for the duration anyway. And if you remove the two mount-to-tranny bolts first, and tip the mount at an angle, you should only need to raise the tranny a minimial distance to clear the stud.
Add to madpogue's Reputation
Old 07-14-2006, 01:09 AM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Its a simple 10 minute job. No need to cut or modify anything.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 07-14-2006, 01:10 AM   #4
RAG man
RAG man is on a distinguished road
RAG man's Avatar
I just replaced my transmission mount on my 99SL2. Do as Madpogue said and remove the 2 bolts for the mount to the tranny first. You should only have to jack the tranny up about 2 inches. Make sure you remove one of the bolts to the upper dogbone before you lift the tranny. Also make sure you follow Luke's instruction to loosen the lower dogbone mount and retighten after all your work is done. http://www.saturnfans.com/forums/showthread.php?t=73563
Add to RAG man's Reputation
Rate the quality of this post and help RAG man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RAG man is offline   Reply With Quote
Old 07-14-2006, 01:21 AM   #5
wolfman
wolfman's Avatar
As others have posted, no "hack job" is necessary.
Add to wolfman's Reputation
Old 07-14-2006, 10:51 AM   #6
eljefino
eljefino's Avatar
1995 SW1
You may in fact need that extra length of threaded rod to position your transmission as you re-lower it. (for leverage) Your trans might move around a little bit when it's up. Watch your fingers.
Add to eljefino's Reputation
Old 07-15-2006, 01:04 PM   #7
oogy
strange! I had gotten the impression from these boards that it was very difficult to raise an automatic high enough to get it to pop out. I was just going on what people said. Never mind :>
Old 07-15-2006, 01:13 PM   #8
Bluesideup
Bluesideup is on a distinguished road
Those people might be the folks who did not disconnect the upper dogbone mount first.
I know I tried to replace the lower mount without disconnecting the dogbone and it was a no go. There was still a little wrestling but it didn't require cutting anything.
Add to Bluesideup's Reputation
Rate the quality of this post and help Bluesideup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bluesideup is offline   Reply With Quote
lower trans mount bdobraj S-Series General 3 12-11-2009 09:50 AM
Lower (trans) Mount mg95SL2 S-Series Tech 9 06-17-2008 11:10 PM
Lower Auto Trans Mount sidney004 S-Series Tech 9 04-08-2008 02:28 PM
is the lower trans mount worn? microsat S-Series General 5 10-10-2007 02:08 PM
just changed my lower trans mount and americanbulldog S-Series Tech 0 11-18-2006 11:39 AM
