Old 06-17-2006, 10:29 AM   #1
DHOOP
DHOOP is on a distinguished road
Default Gas Pedal
What is the usual spot that needs lubrication when the gas pedal sticks in its first 1/8 inch of travel?
Add to DHOOP's Reputation
Rate the quality of this post and help DHOOP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DHOOP is offline   Reply With Quote
Old 06-17-2006, 11:29 AM   #2
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
Default Re: Gas Pedal
It may not be caused by the pedal itself. I suspect you need to clean the throttle body, as the crud buildup can contribute to the pedal "sticking".
Also the pivoting area of the throttle body where the cable attaches can stick and make it feel like a stuck pedal.
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
Add to GreenSC2's Reputation
Rate the quality of this post and help GreenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreenSC2 is offline   Reply With Quote
Old 06-17-2006, 11:54 AM   #3
stlouis1997sl
stlouis1997sl is on a distinguished road
I have the same problem on a 1997sl1. I bought the throttle body gasket but haven't done it yet because I want to pull the IAC and don't know if the IAC gasket and O-ring can be bought seperatly.
Add to stlouis1997sl's Reputation
Rate the quality of this post and help stlouis1997sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stlouis1997sl is offline   Reply With Quote
Old 06-18-2006, 12:09 AM   #4
bonfireking
bonfireking is on a distinguished road
Wife's '97 SC2 had a sticky pedal in the first 1/8th of travel. We just lived with it for a while. But in the midst of other problems, I went to change the Throttle Position Sensor (which is on the throttle body). So I removed the throttle body to do this and found out WHY the pedal sticks... carbon buildup was so bad on the throttle plate it was wedging itself in the body. I could easily feel it trying to turn the throttle by hand.
Solution: with throttle body off (this is simple to get off, it's just two 10mm bolts), I sprayed the innards of the throttle body with WD-40 and wiped everything clean with a rag. By hand I could tell it wasn't sticking anymore. After replacing the TPS I test drove the car and the pedal wasn't sticking at all.
I understand this to be very common amongst Saturns, and it's an easy 1-hour fix at most.
'97 SC2, 200k, rebuild in process
'00 Honda Civic EX, 180k
'87 GMC S15, 80k
'84 Mustang, can't wait to rebuild [again]
'03 Honda CrV, 80k
I'll find more when I mow.
Add to bonfireking's Reputation
Rate the quality of this post and help bonfireking reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bonfireking is offline   Reply With Quote
Old 06-18-2006, 01:53 PM   #5
BarnOwl
BarnOwl's Avatar
It's not a good idea to use WD-40 on a throttle body. The silicone's not good for the O2 sensor. Use carb cleaner or my favorite Deep Creep (sprayable Sea Foam).
Add to BarnOwl's Reputation
Gas Pedal TXSaturn02 S-Series Tech 11 05-27-2009 04:16 AM
gas pedal to the floor Toms XR3 Astra General 7 04-16-2009 03:36 PM
08 Arua brake pedal closer then gas pedal ralphtrent Aura General 11 03-04-2008 05:36 PM
Installing new pedal covers, can't remove gas pedal strongboy2005 S-Series Tech 4 12-09-2006 06:02 PM
rl gas pedal vs non-rl gord888 Ion General 13 06-29-2006 07:12 PM
