Old 04-24-2006, 11:11 AM   #1
Batman87
Batman87 is on a distinguished road
Batman87's Avatar
1997 SL
Default Ignition Coils
My Chiltons says that when changing the ignition coils, new holes should be tapped into the transmition housing to bolt them on, my question is...
Is it really necessarry?
Add to Batman87's Reputation
Rate the quality of this post and help Batman87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Batman87 is offline   Reply With Quote
Old 04-24-2006, 11:27 AM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: Ignition Coils
No, I've never heard of that. The only reason I could think of why, might be to clean up the threads so as to not strip it, or to ensure a good connection. I think they ground through the tranmission housing.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 04-24-2006, 12:59 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
No. Thats sounds pretty dumb. Another reason not to trust the Chiltons or Haynes manuals. Just reuse the same bolts in the same holes. Just dont overtighten so you dont crack the ignition coil.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 04-24-2006, 08:54 PM   #4
Batman87
Batman87's Avatar
1997 SL
sounds good, thanks
Old 04-24-2006, 09:46 PM   #5
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
the reason for all the work on the bell mount is -------
the bolts come with a locktite type coating
this is necessary to prevent the bolts from making a ground connection
if the bolts get grounded
the ignition spark often jumps down the coil tower to the bolt head
instead of going to the spark plug where it should
this is A real crazy thing that Saturn had to overcome early on
it should not happen ,but it really does,as soon as the engine gets warm
I saw it on our S L 2 ,soo I put A blob of rtv blue on the bolt heads
after the old bolts were re-installed ,the bolt heads were insulated
so the jump stopped,the spark went to the plugs instead
no more skipping
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Ignition Coils.... oakraiders24 S-Series Tech 5 03-06-2007 09:58 PM
Ignition Coils Steven62387 S-Series General 3 08-02-2006 01:40 AM
Ignition coils Aldiaz2331 Miscellaneous Tech 4 10-18-2003 10:49 PM
ignition coils wxmd Mods and Performance 11 08-26-2003 02:31 PM
new ignition coils robk Mods and Performance 4 02-21-2002 06:38 PM
