Old 02-04-2006, 04:45 PM   #1
VWman
VWman is on a distinguished road
1999 SW1
Default Rear washer on 99 SW1
Hello all...
My rear window washer has ceased to work during the last couple of months and I figured I'd just wait until better weather to check on it. So today I checked the Hanes manual and the owners manual thinking it'd be as simple as a fuse. Nope. The wiper still works, so it can't be the fuse, plus I checked it anyways and yes the fluid is full.
When I attempt to use some washer fluid there is no sound comimg from the pump. Where do I go from here.
Thanks,
Jerry.
Add to VWman's Reputation
Rate the quality of this post and help VWman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VWman is offline   Reply With Quote
Old 02-04-2006, 05:47 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Rear washer on 99 SW1
Check the wires on the back of the wiper switch. Look through where the wiper lever goes through the shrouds and you may see a broken green wire.
Add to bluesl2's Reputation
Old 02-04-2006, 06:51 PM   #3
Saturn-Eh!
Saturn-Eh!'s Avatar
seen this a few times... yes, remove the steering wheel shroud and look on the right (passenger side) top of the switch. There is a wire there which becomes separated from it's terminal, and will need to be re-soldered. alternatively, you can replace the entire switch, but that is much more costly.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline   Reply With Quote
Rear washer, early SW cityhawk S-Series Tech 12 10-29-2005 06:54 AM
Rear Washer Dribbling cgavula Vue General 21 01-27-2005 10:38 PM
Rear washer - no spray Isophorone S-Series General 7 02-04-2004 06:38 PM
rear washer on new vue judesps Vue General 5 12-13-2002 02:42 PM
97 SW1 Rear Wiper Washer PSU_92 S-Series Tech 3 03-22-2001 10:17 AM
