Old 10-07-2005, 01:29 PM   #1
jilly
jilly is on a distinguished road
1995 SL
Default Refrigerant and Radiator Cooling Fan?
Hi
last week I turned on the AC and a big puff of visible vapor came out of the AC vents. Since then, my coolant fan hasn't engaged at all, causing the temp guage to go in the red if I don't drive with the heat on full blast.
I've printed out the helpful Wolfman's Guide for Diagnosing the Radiator Cooling Fan and plan to work from that this weekend.
My question is: was the visible vapor possibly a refrigerant leak?
Thanks
Jilly
1995 SL
160,000 miles
Add to jilly's Reputation
Rate the quality of this post and help jilly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jilly is offline   Reply With Quote
Old 10-07-2005, 01:34 PM   #2
sierrap615
sierrap615's Avatar
Default Re: Refrigerant and Radiator Cooling Fan?
yes it is possible, how often do you use the A/C? was this right at startup or after the A/C was running for a while? how was the cooling before the vapor? how is your coolant level?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 10-07-2005, 01:39 PM   #3
jilly
1995 SL
Thank you--the AC worked well before the puff...I use it everday. I turned the AC on and got the vapor puff right away.
I haven't really used the AC since the radiator fan quit, though, since I've had to commute with the heat on. So I can't compare how it is working now with before.
My radiator coolant level is fine. I have no to way to test the refrigerant volume myself.
Jilly
Old 10-07-2005, 03:12 PM   #4
BarnOwl
BarnOwl's Avatar
Sounds like a hole in the evaporator $$$, but then all A/C work is. When the A/C compressor engages the cooling fan is turned on to pull more air through the condensor. Most likely your refregerant is low or not there. So, the pressure switch on the A/C won't allow the compressor to engage and the cooling fan doesn't come on. Provided your ECTS is working right, the fan should come on when the gauge is somewhere between 3/4 and the red.
If you've never changed your ECTS, you should with one from a dealer.
Add to BarnOwl's Reputation
Old 10-07-2005, 09:28 PM   #5
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
get that fan fixed first and then go from there.
did the vapor puff have any smell to it? if it was freon, it would be kind of stinky.
2005 Legacy GT LTD
94 SL2
95 SC2
Add to mars_volta's Reputation
Rate the quality of this post and help mars_volta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars_volta is offline   Reply With Quote
Old 10-07-2005, 09:37 PM   #6
jilly
1995 SL
Thank you--no it didn't smell like anything. And I checked the AC on the way home from work and it worked fine. So I am going to get a temperature sensor thingy from the dealer and replace it tomorrow.
Have a good weekend
Jilly
Radiator Cooling Fan Motor is Shot! stitches Vue Tech 8 05-03-2012 10:28 PM
Radiator Cooling Fan not working Zeroherokid S-Series Tech 14 01-17-2008 01:17 AM
Radiator cooling fan relay?? duganator S-Series Tech 3 09-12-2007 01:49 PM
Radiator Cooling Fan Glasact L-Series Tech 4 06-04-2007 02:23 PM
Radiator/AC cooling fan...= dead BEACHBUM S-Series Tech 12 05-23-2006 10:01 AM
