Old 03-21-2005, 11:15 PM   #1
col_j1955
col_j1955 is on a distinguished road
Default 95 SL2 Lost Zip While in Gear (auto trans)
[FONT=Arial]I have a 95 SL-2 which until today has been a zippy car. My wife was driving it and noticed that while in gear it won't go above 2000 rpm and top speed was about 20mph. When put in Neutral it will rev up normally. Can anyone suggest a fix for this problem?
Add to col_j1955's Reputation
Rate the quality of this post and help col_j1955 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_j1955 is offline
Old 03-21-2005, 11:45 PM   #2
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
Default Re: 95 SL2 Lost Zip While in Gear (auto trans)
Check your trans fluid. My moms neon did that too...i pulled over and the cooler lines blew up. Is it just slipping in and out of gear or it just wont go?
Add to the_new_raceman's Reputation
Rate the quality of this post and help the_new_raceman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_new_raceman is offline
Old 03-22-2005, 10:08 AM   #3
col_j1955
The car runs...it's just running sluggish. I did notice some hard shifting at the lower speeds. I'm going to check the trans fluid today. Until then, it's gonna sit in the garage. I didn't notice any leaks.
Old 03-23-2005, 10:45 AM   #4
col_j1955
I've checked the transmission fluid and it's at the right level. Any other suggestions?
Old 03-23-2005, 10:57 AM   #5
the_new_raceman
Im at a loss...any master members wana step up for a crack at it?
Old 03-23-2005, 11:47 AM   #6
geartooth94
geartooth94's Avatar
valve body shot?
is it running rough? you may not be running on all cylinders...
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline
Old 03-23-2005, 11:50 AM   #7
allsaturn
allsaturn is on a distinguished road
2007 VUE 2.2L
Clogged cat?
Add to allsaturn's Reputation
Rate the quality of this post and help allsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
allsaturn is offline
Old 03-23-2005, 08:33 PM   #8
col_j1955
It's not running rough. I'm gonna check for a locked wheel. I have an inclined driveway and I'm gonna park on the incline and put it in N and see if it rolls downhill. Like I said earlier, when in N it revs up great. If I can't figure it out tonite....it goes to the local mechanic.
Old 03-23-2005, 08:55 PM   #9
col_j1955
Now I'm truely baffled. Started the car normally, idle was fine, backed the car out of the garage and parked across the street in neighbors steep driveway. Put it in N and it rolled backwards down the slope (no wheel lock). Put the selector in 3 (to see if it handled the load) and it drove and reved up like normal. Put it in 2 and it did the same. Then put it in D and now it's running normally. Car runs fine, shifts fine, revs up like a champ in the D position. I'm no rocket scientist, but I'm no dummy either.......can't figure this out but the car is running normally now. Perhaps a wheel locked up and released somehow? Maybe I should have the brakes and/or wheel bearings looked at? What's the forum's consensus?
Old 03-23-2005, 11:11 PM   #10
bryan_johnson
bryan_johnson is on a distinguished road
bryan_johnson's Avatar
1994 SC2
Please tell me you checked the parking brake(been there, done that) :-) Sounds like an electrical gremlin of some sort. If the engine would not go over 2000rpm then it's not likely a wheel/brake related problem since in 1st gear 20mph is probably 3-4000rpm on a normal day for you ;-) Besides, that much friction would have made a noticable smell and the drag would have been very noticable. Did any lights come on during the espisode, like the check engine light?
Bryan
Add to bryan_johnson's Reputation
Rate the quality of this post and help bryan_johnson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryan_johnson is offline
Old 03-23-2005, 11:49 PM   #11
col_j1955
That's the funny part...I tried to recreate it with the parking brake....got a noticeable squeal. Remember...I could increase the RPMs when I put it in Neutral. Damn Gremlins!
Old 03-25-2005, 07:32 PM   #12
col_j1955
Okay...get ready for this. After I thought the problem was solved, I got ready to drive the car to work. I started the car and left it running in the garage to warm up. While pouring a cup of coffee for the road, I heard the car stop. I went and restarted it and it wouldn't hold an idle and kept dying. Left it parked in the garage and took a different car to work. Came home and started it up and it kept the idle. Drove it around the block and it won't go above 2000RPM in drive but revs up in Park or Neutral. Sounds like an electrical problem of sorts...is there an ignition module that handles idle and load?
Old 03-25-2005, 10:16 PM   #13
the_new_raceman
check the throttle position sensor, EGR valve, and the crankshaft position sensor. Also when it dies can you smell strong traces of fuel?
Old 04-03-2005, 07:29 PM   #14
col_j1955
I'm giving up...gonna take it in to the shop for a diagnostic check.
Old 04-09-2005, 11:36 AM   #15
col_j1955
Took it to the shop. Mechanic said it's a transmission problem. Seems that it was running in third gear. Transmission shop is speculating "valve body" problem. As this is an intermintent problem, is there a sensor that my be sticking? Can a diagnostic check be performed to pinpoint the culprit? I'm always squeamish about transmission work....how much can I expect the hit to my wallet to be?? Is this something major or minor??
Old 04-09-2005, 04:07 PM   #16
FrozenPilot
FrozenPilot's Avatar
Hows your alternator?
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Replaced Auto Trans will not go into 4th gear C130Flyboy S-Series Tech 1 08-28-2009 04:37 PM
SL1 Auto Trans coming out of gear at speed funfact S-Series Tech 3 05-24-2009 12:02 PM
99 SC1 auto trans. - no 1st gear Road Warrrior S-Series Tech 6 03-16-2008 06:05 PM
2002 L Auto Trans Gear Select Issues brian111 L-Series Tech 2 08-22-2007 09:59 PM
Code 708 and no 1st. gear in auto trans Geronimo S-Series Tech 0 09-17-2006 05:40 PM
