Old 03-21-2005, 03:49 PM   #1
smurf115
smurf115 is on a distinguished road
Default RPM jumps while braking on 00 SL2
I have a 2000 SL2 Saturn and the only problem I've had has been that the RPM has been jumping while I brake to a stop. It's a slight but apparent jump, and it's usually a bigger jump when I'm decreasing from higher speeds.
I love my Saturn, and this is a bothersome problem. The last thing I want to feel while I'm braking is the car trying to push itself forward. I'm not that mechanically adept, and I appreciate any help.
Add to smurf115's Reputation
Rate the quality of this post and help smurf115 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smurf115 is offline
Old 03-21-2005, 03:50 PM   #2
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default Re: RPM jumps while braking on 00 SL2
I believe your car is downshifting....
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 03-21-2005, 04:02 PM   #3
smurf115
Oh.
The reason why I felt it was a problem was because I never remember it happening before.
Simple advice goes a long way. Thanks for your help!
smurf115 is offline
Old 03-21-2005, 05:03 PM   #4
sps SOHC
sps SOHC's Avatar
no problem!
downshifting is good! When it doesn't down shift anymore then you might have a bad alternator. ok! But you would experience other symptoms as well.
sps SOHC is offline
Old 03-22-2005, 02:38 AM   #5
Ruler
Ruler is on a distinguished road
I had a problem very similar to this. It would seem my car would have a loss of power for just a few seconds when I braked and mostly at high speeds.
This problem was fixed after I had took it in. The problem was the connections with the battery. I had tried to fix it myself but was unsuccessful. I winded up taking it in.
Not sure if this is your problem. But it sounds similar to mine so I thought I would post it.
Add to Ruler's Reputation
Rate the quality of this post and help Ruler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ruler is offline
Old 03-22-2005, 04:43 PM   #6
Ernie's 00SWP
Ernie's 00SWP will become famous soon enough
Ernie's 00SWP's Avatar
2000 SWP
This is not a problem.... The cars computer is helping you slow down... While applying your brakes and holding you will see that your rpm's do jump up for a second.. This system assists engine braking.
You can see it in the owners manual on page 225 (which talks about down hill driving).
My 00SWP has always done it when I'm coming to a stop when I hold the brake in one position.... That's when it kicks in...
Maybe someone else can direct you better then I have.. but I can assure you that it's a normal function...
Add to Ernie's 00SWP's Reputation
Rate the quality of this post and help Ernie's 00SWP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ernie's 00SWP is offline
RPM jumps ~1000 @ about 60mph? [Atari] S-Series Tech 6 08-20-2007 01:00 PM
Engine Jumps at high RPM filteritout L-Series Tech 3 06-03-2007 03:40 PM
Grinding ABS + Low RPM/Stall during braking+corning Cortana S-Series Mods 0 02-19-2007 12:07 AM
2000 SL2 Idle Surge when braking. Matt_Agate S-Series Tech 2 11-17-2005 11:56 PM
94 SL2 shaking when braking kindashort S-Series General 8 11-02-2005 08:31 AM
