Old 01-05-2004, 05:06 PM   #1
DJBigDog
DJBigDog is on a distinguished road
Default Rear Window Washer
We have been the proud owner of the 03 Vue since Jan of last year. Currenlty 24k and counting with few problems. I have nothing but praise for the Saturn Vue... However, the rear window washer is terrible. There is no dispersment of the water, it all just runs down the window. Is this normal or do I need to get it repaired???
First post ----- Great site!
BD
Add to DJBigDog's Reputation
Rate the quality of this post and help DJBigDog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DJBigDog is offline
Old 01-05-2004, 05:07 PM   #2
jmatero
jmatero is on a distinguished road
jmatero's Avatar
Default
That's how it is designed (Unfortunately....). It's pretty bad, I know!
Add to jmatero's Reputation
Rate the quality of this post and help jmatero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmatero is offline
Old 01-05-2004, 05:15 PM   #3
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default Re: Rear Window Washer
BD
I would suggest a rear deflector which helps keep the window clean. It's an easy install yourself and you can get at saturnaccessories.com. I rarely use my rear washer
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 01-05-2004, 05:17 PM   #4
ricksLS1
ricksLS1's Avatar
BD
I would suggest a rear deflector which helps keep the window clean. It's an easy install yourself and you can get at saturnaccessories.com. I rarely use my rear washer.
PS Welcome to the board!!
ricksLS1 is offline
Old 01-05-2004, 05:29 PM   #5
KJB
KJB is on a distinguished road
KJB's Avatar
Default
Mine just kinda pees down the window as well.
Add to KJB's Reputation
Rate the quality of this post and help KJB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KJB is offline
Old 01-05-2004, 10:11 PM   #6
silvervoo
silvervoo is on a distinguished road
silvervoo's Avatar
2003 VUE 2.2L
Default
I think that is by design. If it was a mist or spray instead of a stream, the fluid would miss the window altogether when you're going fast.
●● If it doesn't have a clutch, I'm not interested ●● Vive la bote manuelle ●●
Add to silvervoo's Reputation
Rate the quality of this post and help silvervoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silvervoo is offline
Old 01-05-2004, 10:20 PM   #7
20VUE06
20VUE06 is on a distinguished road
20VUE06's Avatar
Default
Yes, this was by design from what I hear. The idea was that if it sprayed from the nozzle, it would just mist the cars behind you and not get the window because of the air disturbance. I just kinda push the tab a bit as the wiper moves through it's path so that it grabs as much fluid as possible instead of letting it drip down as the wiper is on one side or the other... Works for me.
2004 Vue AWD V6
Add to 20VUE06's Reputation
Rate the quality of this post and help 20VUE06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
20VUE06 is offline
Old 01-05-2004, 10:37 PM   #8
Doug Woolf
Doug Woolf is on a distinguished road
Default
Mine does a good job actually. Sprays a mist. Does the job! I would have them look at it. Still under warranty! :')
Add to Doug Woolf's Reputation
Rate the quality of this post and help Doug Woolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Doug Woolf is offline
Old 01-05-2004, 11:59 PM   #9
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
No, they are supposed to spray a stream. If yours mists, you have the wrong nozzle installed.
~D.J.~
OhioVueBoy is offline
LW1 Rear window washer OldGoatDJ L-Series Tech 1 10-22-2008 02:59 PM
01 SW2 rear window washer SL2Many S-Series Tech 1 09-13-2008 09:29 PM
Rear Window Wiper/Washer Steamrunner 2008 Vue 7 11-28-2007 01:27 PM
Rear Window washer fluid.... 05vueblue Vue Tech 4 09-13-2005 04:49 PM
Rear Window Washer Problem? KI8GW Vue General 2 07-04-2004 07:39 PM
