Old 12-24-2003, 01:02 PM   #1
viperman7116
viperman7116 is on a distinguished road
Mad Replacing SL1 ECU
I was wondering if anybody could help me out. Is paying $900 to much to pay at the dealership to have them replace the ECU which is not even fully guraneted to fix the problem with my car. How hard would it be to buy an ECU and install it myself? Or is it probably beter to just buy a new car. Ive spent about $3000 on my car in the last month, and its not even worth that much. Its a 97 SL1 with 106,000 miles on it. So is it better to fix this problem or to just go buy a new car?
Add to viperman7116's Reputation
Rate the quality of this post and help viperman7116 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
viperman7116 is offline
Old 12-24-2003, 02:26 PM   #2
amazinghl
Default
What is wrong with the car?
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 12-24-2003, 11:38 PM   #3
viperman7116
Default 97 SL1 ECu
well the problem with the car is that it is hard to start constantly over revs and is quite frequent to stall out also my gas mileage has gone way down
Old 12-25-2003, 01:27 AM   #4
amazinghl
Default
That sounds like the ECTS and Thermostat problem, NOT the PCM. *by the way, do NOT EVER go to that dealer ship again, they know nothing*
What is the other $3000 you spent on?
Check here to look for how-to to change both item. They cost less than $40, if you change them yourself.
http://www.saturnfans.com/forums/sho...threadid=26532
00 Insight 72mpg
Old 12-25-2003, 01:28 AM   #5
mtlmutt
mtlmutt is on a distinguished road
Default
I've worked for Saturn for over 10 years now and replaced maybe
5 ECU's. I would do a fuel pressure test on it first (especially a 97) even the new pumps were bad out of the box in 97! it sounds more like a IAC motor or ECT could be causing this.
What codes are you getting?
Add to mtlmutt's Reputation
Rate the quality of this post and help mtlmutt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mtlmutt is offline
Old 12-26-2003, 12:03 AM   #6
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
Second that - bad PCM's on Saturn S-series are like hen's teeth - rare.
If it hasn't been changed, change the ECTS, and check the fuel pressure after a 8hour shut-down. The 97's were notorious for bad pumps, though the typical symptom is extended crank when starting.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 12-26-2003, 12:23 PM   #7
BobL
BobL is on a distinguished road
Default
If you really need one, try Joe Cutrone at www.6thplanetusedparts.com
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Question about replacing my ECU BasilCarey S-Series Tech 41 11-26-2009 06:49 PM
Replacing my 95 SL1 - Thank you for all your help! kkspeed S-Series General 0 04-25-2009 03:36 AM
Thinking of replacing engine in 96 SL1 harley2003 S-Series General 3 03-29-2008 09:26 PM
replacing rotors and pads on 95 sl1 studentinhiker S-Series General 4 03-26-2006 08:45 PM
Replacing Horn on 96 SL1 Dr. Bob S-Series Tech 7 08-12-2000 06:45 PM
