Old 02-08-2020, 11:52 PM   #1
Ccrussell
Ccrussell has a spectacular aura aboutCcrussell has a spectacular aura aboutCcrussell has a spectacular aura about
1999 SL1
Default Wheel bearing
Hello,
Driving home the other day I hear a wheel bearing howling. Sounds like the right front , pass side. Had a fresh timken in the garage, had it pressed in, I reassembled and, alas it was not the culprit.
When turning slightly left I can hear the noise lessen.
Any easy way to diagnose with greater accuracy the corner of the car it's coming from?
At least my next pick gives me a 1 in 3 chance of correct.
Add to Ccrussell's Reputation
Rate the quality of this post and help Ccrussell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ccrussell is offline   Reply With Quote
Old 02-09-2020, 01:22 AM   #2
onlinebiker
Default Re: Wheel bearing
Jack the wheels up one at a time - and try forcing the wheel top to bottom. That is - one hand on top outside, other hand bottom inside. A bad bearing will usually be indicated by a felt clunk......
I might suspect a CV joint...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-09-2020, 01:43 AM   #3
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
I've had a number of wheel bearings on Saturns that have no discernible play even when the bearing sounds like its about to fall off
spinning while placing your hand on the spring, Ive had varying success with that
Running it up to 40mph while well supported on jackstands 99% success
CV joint, wheel bearing, intermediate bearing, differential bearing 1 in 5?
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
me.theuser is offline   Reply With Quote
Old 02-10-2020, 11:03 AM   #4
hholbein
1997 SW2
+1 Here's a video of Eric the Car Guy isolating wheel bearing noise.
https://www.youtube.com/watch?v=cdRpnK5MGQ8
Add to hholbein's Reputation
Old 02-10-2020, 12:24 PM   #5
me.theuser
2002 SL1
2001 SL2
Woo thats a bit scary I jack up both sides and listen to both sides with someone else in the car
Old 02-12-2020, 09:23 PM   #6
hholbein
1997 SW2
I'd be more scared with both fronts on jack stands! Just be super gentle with braking.
How to tell if wheel bearing is bad? DonP1 S-Series Tech 14 11-28-2018 03:55 PM
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Which wheel bearing? MarleyPud Vue General 10 08-10-2014 07:09 PM
Wheel Bearing? rickystarshine Ion Tech 2 01-08-2011 12:54 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 11:16 PM
