Old 01-30-2020, 09:02 AM   #1
datlas
datlas will become famous soon enough
Default 180K Day on Original Clutch
Nothing earth shattering, but it helps push the spam down.
I should be hitting 180K today or tomorrow. Original owner 1998 SL. Original clutch.
I know that 180K for my Satty is really only "middle age" but I also wonder if I can keep going on the original clutch. It works fine.
What's the expected lifespan of a clutch, assuming I continue to drive it conservatively as I have been doing?
Add to datlas's Reputation
Rate the quality of this post and help datlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
datlas is offline   Reply With Quote
Old 01-30-2020, 10:29 AM   #2
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
Default Re: 180K Day on Original Clutch
My clutch at 204,062 had plenty of life left. Probably another 100,000 anyway.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-30-2020, 01:18 PM   #3
onlinebiker
It goes further if you shift (correctly) without using the clutch.
I have seen 340,000 miles shifting without (1978 Olds Omega) and the transmission showed no wear...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 01-31-2020, 06:11 PM   #4
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
If it works fine, then don't worry about it. Every so often, I floor it in 5th as a test.
I had to replace mine at 140k. The rear engine seal was leaking and the clutch slippped when starting on hills or flooring 5th. All kinds of grease and gunk when I took it apart. That said, I couldn't tell the difference on the material between the old and new kit (it looked the same width), so it looked like there was little actual wear at that mileage.
I'm now at 287k miles, and the car drives just fine.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 02-04-2020, 08:07 AM   #5
BV22
2002 SC1
When I retired my Saturn it had 315k on the original clutch, and I always used it when shifting. Part of long life is technique. Part is that I live in a flat region of the country. Launch with as little RPM as possible, and never sit at a stop light with the car in gear and the pedal pushed. Put it in neutral and foot off the pedal when stopped.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 02-04-2020, 08:22 AM   #6
onlinebiker
Saturn built a good clutch. My SO's first 96 SC2 had 300k+ on the original clutch when I swapped drivetrains in it. (Low compression)
She used it all the time.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-04-2020, 08:24 AM   #7
Waiex191
Waiex191's Avatar
The only reason I swapped my clutch at 204K is we had it apart for an engine rebuild. But the stage 2 clutch we used was crap. We just put a stock Luk clutch in at about 222K. I suspect we will never change it again.
Bryan Cotton
Old 02-04-2020, 08:29 AM   #8
datlas
Good news. I am afraid if the clutch goes, my wife will force me to pitch the car. She thinks we should not put any more money into it.
Luckily, it just passed PA state inspection so unless something catastrophic happens, I am good for another year!
Change Transmission Fluid at 180K? xfriendsonfirex S-Series Tech 8 04-15-2014 09:07 PM
How many miles have you gotten on your original clutch? Midnight13 S-Series General 12 02-03-2011 02:54 PM
advice on '97 with 180k and chocolate shake smelm0 S-Series Tech 6 11-09-2010 04:39 PM
1997 SL 180k miles mikeri S-Series Tech 2 10-09-2008 01:37 PM
Buying a '97 180k mile SL2 RandomOr S-Series General 5 11-21-2005 10:22 AM
