Old 01-30-2020, 04:51 AM   #1
Mister_Cee
Mister_Cee is a jewel in the roughMister_Cee is a jewel in the roughMister_Cee is a jewel in the rough
Default I known the SATURN acronym...
S orry
A bout
T hat
U gly
R attling
N oise
But, I've had my 1996 SW2 since it came off the showroom floor and there's now a rattle that I can't localize and mute (and, believe me, I've become pretty good at suppressing rattles in the car)
It seems to be coming from the lift gate but the latch isn't loose, and trim pieces that were loose have been shimmed so they aren't causing the rattle.
There are the two license plate light "fixtures" that seat okay but aren't tight. But I don't see how that small rattle could be causing the louder one I'm hearing.
Anyone have any experience with this?
Add to Mister_Cee's Reputation
Rate the quality of this post and help Mister_Cee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mister_Cee is offline   Reply With Quote
Old 01-30-2020, 07:56 AM   #2
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
Default Re: I known the SATURN acronym...
I thought U was for unbearable.
My '98 has been poorly cared for by the PO and everything rattles.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-30-2020, 08:51 AM   #3
454cid
My sun roof shutter rattles.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2020, 08:53 AM   #4
Highmile
Highmile's Avatar
I thought U was for Undesirable...
Highmile
'95 SL1 700k and counting
Add to Highmile's Reputation
Old 01-30-2020, 09:05 AM   #5
trottida
trottida's Avatar
I thought it was for "unknown" which kind of fits in this case.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-30-2020, 09:41 AM   #6
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
My Saturn doesn’t actually rattle that much.I’ve gotten to be pretty good at locating the places that do though. It’s not a perfect method, but I usually just press on different trim pieces until it stops. There’s not always a lot I can do to fix it, but after a while you get used to where they’re coming from and how annoying they’re gonna be.
97 SL2, auto, 118K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2020, 05:05 PM   #7
hholbein
1997 SW2
First, the "gasket" that GM used to seal the license plate to the fiberglass liftgate is a cheezy foam thing that disintegrated 15 years ago on my SW2.
It was a water leak when parking on downhill grades that prompted me to fix it.
I used a roll of warmed up duct seal around the edges of the opening and no noises or leaks since. You'll need to remove the interior tailgate trim to do a proper job of it.
One other thought is to play some music loudly from the rear speakers only and with a range of frequencies to see if that reveals anything.
Another possible source of rattling is the very poorly-designed 2nd seat latch on 2nd Gen/3rd Gen models. Lots of buzzes and rattles with that POS.
Let us know how you get on.
Add to hholbein's Reputation
Old 01-30-2020, 05:30 PM   #8
onlinebiker
Other alternatives - a career in rock and roll or Army Artillery....
In twenty years or so you won't hear those pesky rattles anymore.....
Or much of anything....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 01-30-2020, 10:45 PM   #9
Mister_Cee
LOL
I was a musician, by trade, and stood in front of amplifiers for years. I think that's about the same level of noise saturation. I DO have loud tinnitus though, so I've got that going for me lol
Old 01-30-2020, 10:46 PM   #10
Mister_Cee
Ugly, unbearable, undesirable, unknown ...yup they are seem to fit this circumstance
Old 01-30-2020, 10:48 PM   #11
Zeebins
Zeebins's Avatar
That one is by far the worst. I always have to shove something between it and the seat.
Powered by Plastic
Old 01-30-2020, 10:58 PM   #12
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
That is why I have a full aftermarket sound system in both my 98 SL2 and my 04 Blazer. With the windows rolled down, the sunroof roller back, and the stereo cranked to 11, you don't hear any rattling
Well, not really the case in the Blazer... 1200 watts pushing a pair of 12"s, everything rattles...
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98_Gold_Uranus is offline   Reply With Quote
Old 01-31-2020, 09:59 AM   #13
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
I got used to all the rattles and buzzes. I’m married.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 01-31-2020, 06:16 PM   #14
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
True story, I had a German co-worker that I gave a lift once.
He was impressed by the mileage and longevity of the car, but when he got out and closed the door he turned around and stared. With a small chuckle that evolved into a laugh, he then took out his phone and took a video of the door opening and closing.
I asked him what he was doing, and he said that he couldn't believe that a car would rattle that much when simply closing the door, and he had to send it to all his German friends. I guess I'd gotten used to the plastic door sound by that point.
Good luck with the sound check. Have you checked below the trunk/spare cover and make sure everything's secure underneath? Maybe the screw for the spare or the jack's come loose.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 01-31-2020, 07:39 PM   #15
bumpdraft
bumpdraft's Avatar
1998 SW2
The S-Series might be based on an Audi 5000, but the S-Series doors do not sound remotely like a door closing on an Audi 5000
I recently put wheel covers on my winter steel wheels for the first time since 1998, and I am impressed at the POS rattle, but not in a good way. I might go back to looking gangsta or, just turn up the pop music.
Add to bumpdraft's Reputation
Old 01-31-2020, 09:59 PM   #16
Zeebins
Zeebins's Avatar
I recently pulled the plastic panel off the trunk lid and I was surprised how much more satisfying it was to close with it off. That thing rattles so much closing the trunk it feels like something is going to break. Without it there’s actually a decent thud. (It’s also missing a screw for some reason so maybe that is part of the problem)
Powered by Plastic
Old 02-01-2020, 01:50 PM   #17
bumpdraft
bumpdraft's Avatar
1998 SW2
You nailed it! Some of us are not “detail oriented” and then we blame a 20+ year-old plastic car, when a metal car of that age would be full of rust holes. - Sounding good, but looking like heck.
My wheel covers are missing the plastic spacer ring that make it fit tight to the wheel. A roll of 3M foam tape, in place of the missing plastic spacer ring, will probably fix the rattle. ...and my trunk lid has been involved in two accidents, each accident resulting in an immobilized vehickel.
Old 02-01-2020, 06:16 PM   #18
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Adding Neoprene Washers has helped my little rattles almost as much as playing Bach's Passacaglia and Fugue in C Minor on a good stereo system with the windows down.
https://www.youtube.com/watch?v=nVoFLM_BDgs
I believe the bass scares the rattles away and you get funny looks from the kids driving - my favorite part.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-04-2020, 05:47 PM   #19
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by bumpdraft View Post
...My wheel covers are missing the plastic spacer ring that make it fit tight to the wheel. A roll of 3M foam tape, in place of the missing plastic spacer ring, will probably fix the rattle....
Two layers of foam tape. I think the entire wheel cover sits too far from the wheel. Is it that the Dormann lug nuts are taller and the plastic bolts bottom too soon? P e r h a p s so...
weatherstrip adhesive applied after the tape. It should help hold the edge of the tape so that wet road grit is not forced under it.
Old 02-04-2020, 07:29 PM   #20
onlinebiker
5 years in a garage band. 5 years as a Coast Guard radio man. 20 years as a machinist. 35 years of motorcycles with no helmet. 50 years of firearms. Rock and Roll, crashing static. Punch presses thundering.100 mph wind noise. Millions of rounds of ammo..
You expect me to hear a little rattle?
Bwaaaahahahaha......
You guys.....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Saturn Racing Group Saturn Show at Saturn of Tempe ry92sc Events 7 01-23-2005 09:38 PM
