Old 01-04-2020, 06:00 PM   #1
Bo Markham
Bo Markham is on a distinguished road
Dizzy Interesting Problem
Hi all,
My 06 2.2L 5 spd. Vue has developed an unusual problem. When I refuel and close the gas cap. The car doesn't want to start. After several attempts at starting, with no success, I have to hold the accelerator pedal to the floor. The car will then start, but run really rough for a few seconds then straighten out and run fine. Will not give me any problems until I again stop to refuel. Same thing happens. This has happened twice, now.
No engine check light, or any other indication of a problem. Nothing?????
Anybody have this happen to them?
Any ideas?
Bo
Add to Bo Markham's Reputation
Rate the quality of this post and help Bo Markham reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bo Markham is offline   Reply With Quote
Old 01-04-2020, 06:30 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Interesting Problem
It sounds like your evap canister purge solenoid may be stuck open. If it sticks open, fuel vapors will go into the intake manifold creating a temporarily rich condition. If it only happens after fueling the car, that's most likely what it is.
Add to bluesl2's Reputation
Old 01-04-2020, 09:39 PM   #3
Bo Markham
Is there a procedure for testing this? I'd really hate to start replacing stuff without knowing for sure. Kinda gets expensive.
Old 01-05-2020, 01:25 PM   #4
bluesl2
bluesl2's Avatar
It's in the engine compartment, it's exact location escapes me right now. Look for a solenoid with one electrical connector with two wires going into it and two vacuum hoses hooked to it. One vacuum hose goes back to the back of the vehicle and the other goes to the intake manifold or an intake vacuum source. Disconnect the one going to the back of the vehicle and start the engine. Use your finger/thumb and put it on the fitting on the purge solenoid where you disconnected the hose from. You should not feel vacuum there, if you do the valve is stuck open or the diaphragm is ruptured.
Old 01-05-2020, 02:31 PM   #5
Bruce Rock
2000 SL2
2006 VUE 2.2L
It's on the output (drivers side) of the engine. Easy to get to.
https://www.youtube.com/watch?v=5E309UVBopY
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Interesting problem TheCOS2012 L-Series Tech 1 06-06-2012 05:58 AM
Interesting charging problem Sid S-Series Tech 5 07-16-2011 10:03 PM
Interesting new problem s3nfo L-Series Tech 8 03-03-2010 11:03 AM
interesting clutch problem.. Swapped96Sc1 S-Series Tech 9 07-31-2008 04:53 PM
Very interesting little problem with an sl1... can you solve it? acr2001 S-Series General 6 10-11-2005 01:32 PM
