Old 12-01-2019, 04:22 PM   #1
Homerlasvegas
Homerlasvegas is on a distinguished road
Default 2003 Saturn Vue 2.2L Manaul P0300
Hello, I have a 2003 Saturn Vue 2.2L Manual. It was running great then the other day suddenly my low coolant light came on.. It still has coolant in the reserve tank. It ran ok for a few days then starting bucking and hesitating. Engine light starting flashing. Then it cleaned up.. Light went off. Drove it further .. it started again. It seems that when I get on the gas hard 1/2 to 3/4 it just wants to bog down. If i Go lighthly, it seems to run ok.
Ideas help? Where do I go.. The coolant is below the minimum fill line but still about 3 to 4 inches in the reserve tank.
Also, in diagnosing, noticed that the when I pulled off the oil fill cap I was getting quite a bit of blow through. I this normal? Help is greatly appreciated. This little Vue is my daily driver. I really need it running.
I also have p0440, and got one read of a p2019.
I do have the Torgue App. What other readings can help diagnose this issue.
Add to Homerlasvegas's Reputation
Rate the quality of this post and help Homerlasvegas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homerlasvegas is offline   Reply With Quote
Old 12-01-2019, 05:21 PM   #2
waiter21
2003 VUE 2.2L
Default Re: 2003 Saturn Vue 2.2L Manaul P0300
How many miles??
Any work performed on timing chain, tensioner? 2003 is a year where you may have an older Tensioner that could cause the chain to jump (not related to your current problem). If the chain jumps timing, it destroys the engine.
For the problem you described, my first thoughts are bad/dirty ground connections on the engine. Hers a link that may be of interest:
http://www.saturnfans.com/forums/sho...d.php?t=216101
My second thoughts are bad o-rings on the intake manifold and possibly a plugged PVC port. Scroll down about post #6
http://www.saturnfans.com/forums/sho...d.php?t=217319
Add to waiter21's Reputation
Old 12-01-2019, 05:42 PM   #3
I think you're Vue has several issues; allowing coolant to remain below minimum level (the reason for a low coolant light), possible misfiring generating a flashing check engine light that can destroy the catalytic converter if not addressed immediately, P0440 and P0219.
1.Refill the coolant reservoir with either plain water or antifreeze to the cold mark to ensure coolant is adequate. Allowing coolant to remain below minimum level is a risk. If there's a coolant leak and coolant never went low, this might be a hint of cooling system problems. Good cooling systems retain coolant levels without requiring periodic refilling.
2.The flashing check engine light (P0300) means a major misfiring event is occurring with one or more cylinders not igniting the fuel/air mixture. The unburned mixture exits the engine into the exhaust system. The catalytic converter is already hot and ignites the unburned fuel. If allowed to run this way, the catcon will simply burn out from excessive heat from unburned fuel. As little as 50 miles of driving with the flashing check engine will burn out the catcon.
When were spark plugs replaced? Air filter? Oil?
3.P0440 - https://www.obd-codes.com/p0440
4.P0219 - https://www.obd-codes.com/p2019
Old 12-03-2019, 06:55 PM   #4
bluesl2
bluesl2's Avatar
You may want to do a compression test. If coolant is going down with no external leaks either you have a head gasket leaking or maybe the water pump may be leaking. Pressure test the cooling system to see if the pressure drops.
Add to bluesl2's Reputation
Old 12-15-2019, 01:43 PM   #5
Homerlasvegas
Ok So I changed the plugs and boots.. Seemed to fix the problem... for 50 miles. Now its back with the only "RED" error current fault.. P0420.
I changed the plugs.. cleaned the intake it was dirty.. actually had some oil in it.. like maybe it came from the pcv??
Now this is what is happening above about 1800 RPM and at standing idle it seems fine. however between 1000 to about 1500-1800 rpm it does not want to run smoothly. also I can not idle away from a stop. I use to be able to.. It starts just a tad harder then it use too.
My grey faults are p0300, p1599, p0104, u20bf.
I am using a generic usb obdII reader with the Tourgue app.
I am going to check and clean all grounds. I also have a new upstream O2 sensor to put on the car.
HELP??
2003 Saturn L300 Code P0300 ELRJ2 L-Series Tech 33 11-01-2015 09:44 AM
2003 Saturn L200 2.2L Code P0300 ronep L-Series General 4 04-02-2014 08:57 AM
2003 saturn L300 codes p0050 & p0300 tylerjoe500 L-Series Tech 11 07-21-2010 07:07 AM
Shifting problem, 5 speed manaul w-in-ga S-Series General 2 02-08-2010 01:21 PM
98 SC1 Manaul Transmission HELP PLEASE!! Jerz3455 S-Series Tech 23 10-18-2007 08:51 PM
