Old 11-03-2019, 03:51 AM   #1
mjollnir79
mjollnir79 is on a distinguished road
Default P0302 Cylinder 2 misfire detected
Open loop due to insufficient temperature.
This is with a 1996 Saturn SL2.
This is my wifes car. Happened after having a hell of a time with getting a new crossmember in. Had to muscle around the engine quite a bit.
This reminds of an issue with my old SL2 I had before my current car, an ION.
It was a temperature sensor.
Could this be it?
Add to mjollnir79's Reputation
Rate the quality of this post and help mjollnir79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjollnir79 is offline   Reply With Quote
Old 11-03-2019, 12:57 PM   #2
mjollnir79
Default Re: P0302 Cylinder 2 misfire detected
Ok changed the engine coolant temp sensor. Still getting the "Open loop due to insufficient temperature." or fuel system status though. But car now turns over no prob.
Old 11-03-2019, 01:56 PM   #3
bluesl2
bluesl2's Avatar
Probably your seal on your thermostat is shot allowing coolant to bypass the thermostat, or the thermostat isn't closing correctly. Either way, probably time for a new thermostat. Double check and make sure you have a brass tipped coolant sensor and clean corrosion free connector as well. Doesn't have anything to do with your cylinder two misfire though as your title of the thread though.
Add to bluesl2's Reputation
Old 11-03-2019, 02:23 PM   #4
mjollnir79, with a reader on hand and if the t-stat is running cooler than expected, use your reader to monitor actual coolant temps. With a new coolant sensor, initial temps should be close to ambient at ignition on time, cold engine. When warmed up, coolant should be between 185F-195F. If below 185F, replace the t-stat.
P0302 cylinder #2 misfire may be; faulty spark plug, spark plug wire, lost compression, etc.
Old 11-03-2019, 02:45 PM   #5
mjollnir79
I cleared the code after I changed the sensor and it's not coming back. Seems fine for the most part. RPMs are good.
P0303 - Cylinder #3 Misfire Detected d4rkf1ber S-Series Tech 3 11-25-2019 04:14 PM
P0302 - Cylinder 2 Two Misfire Detected Tripp S-Series General 11 06-28-2012 03:44 PM
OBD Code: P0301 Cylinder 1 Misfire Detected hc803 S-Series Tech 16 01-22-2007 12:25 PM
96 sl2 P0302 Cylinder 2 misfire??? bskicrash1 S-Series General 15 12-26-2005 12:22 PM
P0302 Cylinder 2 misfire. M.Nguyen S-Series Tech 4 04-07-2005 12:33 AM
