Old 08-01-2019, 06:23 PM   #1
genscripter
genscripter is on a distinguished road
Default 2000 SL1 randomly idles really low
Haven't had many problems with my SL1 for years. Then yesterday, I was pulling out of the driveway, when it started idling really low. I gave it some gas and it was fine, but every once in a while at a stop light, it will idle crazy low, like 500rpms. Almost like it's going to die. For a second, it feels like it does die.
I got it home and ran my OBD scanner. No warnings or codes. It say all is fine.
Any ideas?
Add to genscripter's Reputation
Rate the quality of this post and help genscripter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
genscripter is offline   Reply With Quote
Old 08-01-2019, 11:43 PM   #2
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
Default Re: 2000 SL1 randomly idles really low
Ideas would be IAC valve or TPS.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-02-2019, 09:13 AM   #3
toggenburg
toggenburg's Avatar
Both are inexpensive and easy to replace. Right atop the throttle body.
Old 08-06-2019, 12:00 PM   #4
TomM96
Standard Motor Products packages a spare set of screws with one of their options, which i appreciated, after dropping a screw.
Add to TomM96's Reputation
TomM96 is online now   Reply With Quote
Old 08-11-2019, 08:39 PM   #5
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
mine does that from time to time, after a few cycles it will light the SES light, code is EGR valve related. In my case, the EGR Valve was dirty. To see if that is your issue, take the care out on the highway and keep it in a lower gear and drive it at 4000 RPM for a minute. That will force any stuck dirt out of the EGR Valve. If this corrects your issue, it is best to then take the EGR valve off and clean it. See video on removing and cleaning. www.youtube.com/watch?v=bt5lRTt6BsU
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 08-11-2019, 09:46 PM   #6
bluesl2
bluesl2's Avatar
Even though it may not be the issue, would not be a bad idea to make sure you have the updated ect sensor and clean corrosion free connector. If it were me, I would pull the throttle body off and clean it good or you could leave it on the car and clean it if you don't have a new gasket handy. My 97 a few years back had an issue very similar where I had to feather the gas turning corners because it felt like it was going to die. Cleaning the throttle body cured it. There is a possibility of an EGR issue as well, but I would try the cleaning of the throttle body first.
Add to bluesl2's Reputation
Old 09-19-2019, 07:37 PM   #7
genscripter
Thanks for all the suggestions. I'll check them out tomorrow.
Old 09-27-2019, 01:49 PM   #8
genscripter
I took the throttle body off and cleaned it up. It was sticking a bit.
Also, I replaced the IAC valve and TPS.
I noticed my old one was stuck open. Look at the comparison below: (new on the left)
I put it all back together, and now it revs up and doesn't come back down to idle. The only thing that stops the increase in RPM's is turning the key off.
Is my valve faulty? I would expect to see some movement in my new valve, but maybe I'm wrong. What does a good valve supposed to look like.
Old 09-27-2019, 01:52 PM   #9
Highmile
Highmile's Avatar
Your valve is fine... start it and let it run. It will take a couple of minutes for the new valve to adjust out and bring the idle down.
If this doesn't cure your idle issue then check the plugs, wires, and coils.
Highmile
'95 SL1 693k and counting
Add to Highmile's Reputation
Old 09-28-2019, 03:03 AM   #10
genscripter
Highmile
Thanks for your advice. I read your post, reassembled everything again and fired it up. It high idled for about 45 seconds, then gradually went down to normal idle speeds.
I drove it around all night and everything is back to normal. Thanks for all the help on this.
My 2002 Saturn SC1 idles at 2000 RPM while in park. There is also a knocking sound. travisj027 S-Series Tech 10 03-14-2019 01:16 PM
'05 Vue Randomly Shutting off kagansmom Vue Tech 5 11-10-2013 08:03 PM
Radiator fan comes on randomly Packrat1 S-Series Tech 8 12-08-2012 12:47 AM
LS 2000 - electrical issues - randomly doesn't start phitchow L-Series Tech 3 10-04-2012 10:19 AM
car idles high, 2000 rpm idle pimpin88 S-Series Tech 7 12-11-2009 06:49 PM
