Old 07-31-2019, 02:14 PM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Sealant
Anyone know of a good metal to metal sealant? Not gasket maker. Sealant?
Add to Tyson's Reputation
Rate the quality of this post and help Tyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyson is offline   Reply With Quote
Old 07-31-2019, 04:34 PM   #2
Default Re: Sealant
What are you sealing? There's RTV for making instant gasket as machining allowed better finishes to use RTV as a sealant. Thread locker to prevent nuts and bolts from vibrating loose. Weatherproof sealant used to bridge gaps between metals to prevent water intrusion.
Old 07-31-2019, 08:19 PM   #3
Tyson
Default Re: Sealant
METAL to metal
Old 07-31-2019, 10:22 PM   #4
toggenburg
toggenburg's Avatar
Default Re: Sealant
Depending just where and what you are sealing, you could easily and cheaply use silicone in a caulk tube. Inexpensive, easy to apply (wait 24 hours to cure before water exposure). Found at any big box store like Capps, Homedepot, Lowes, Mennards....etc.
Old 07-31-2019, 11:43 PM   #5
pierrot
pierrot's Avatar
Default Re: Sealant
The suggestion by toggenburg makes sense to me. It would be helpful to know where on the car this will be applied and what you're wishing to keep sealed out; e.g., air, water, oil, hydraulic fluid, etc...
329,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Add to pierrot's Reputation
Old 08-01-2019, 08:42 AM   #6
Tyson
Default Re: Sealant
Itís on the water inlet unit. Not thermostat housing or water pump. Itís on opposite side of block. I replaced this thing put correct torque on it and itís just seaping at the top. I tried gasket makers and sealant but Iím worried that if it gets on o ring itíll not allow o ring to work properly. The part is in such a tight spot that itís impossible to line it up without smearing that gasket maker all over. Do you have any advice?
Old 08-01-2019, 10:40 AM   #7
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Sealant
I wet the o-ring with a good quality silicone sealant when installing parts like this. It helps seal small imperfections in the steel parts and helps prevent shearing a small piece of the o-ring.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 08-01-2019, 09:42 PM   #8
Default Re: Sealant
As fdryer said in one of your other multiple posts you should stick with one post for the same problem. Makes things so much easier for anyone trying to help you out.
Also as he said PICTURES.
You don't think that you can get a good close in picture then get what you can. At the very least a picture of the area so that we can guess more precisely of the "water inlet" that you are talking about.
As for today's post --- a metal to metal sealant. The type of sealant will depend on what you are sealing against because some sealants don't like certain materials/liquids. Where it is you are trying to seal. The amount of space between the two surfaces. Movement/flex.
Add to ssicarman's Reputation
Old 08-02-2019, 06:48 AM   #9
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default Re: Sealant: the old what one to use trick
hi sages- have used many different sealants in varied applications on cars, many successfully and others going stinko fast. to name a few good ones: seal all, gasket cement, jb weld epoxy, 3M black cement, gorilla glue. curious as hell about your opinions on applicability and effectiveness of one heavily advertised product which I have not used yet- flex seal in tubes,cans,sprays and tapes. any users here? thanks tons bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rfisher is online now   Reply With Quote
Old 08-02-2019, 12:52 PM   #10
Dsaturn
Dsaturn is just really niceDsaturn is just really niceDsaturn is just really niceDsaturn is just really nice
2001 L-Series 2.2L Sedan
I have used the Flex tape with great results. It also makes a great temp patch on my jeep to cover rust for State inspection. I also used it on a plastic 400 gallon water tank that got a crack in it. Where the crack is there is 200 gallons of water sitting on it. Not even a seep from the crack.
https://www.infowars.com/
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is offline   Reply With Quote
Old 08-03-2019, 09:12 AM   #11
rfisher
Default Re: Sealant
hi dsat- that's a good story with the tape. will get a small quantity to try and also get the flex paste sealant in the tube. nj has always had annual car inspections. seemed everybody automatically failed for emissions. they would fail you for any holes on the body from rustout. typical body shop wanted at least $500 to repair(fill hole with bondo), but if you put duct tape over the hole you passed. last time I checked duct tape was 3.00 for a small roll. what would you do with your 497.00 savings. btw duct tape repairs and rust holes in your Packard will you out of the yacht and country club. sorry. bob f
Old 08-03-2019, 05:32 PM   #12
Tyson
Default Re: Sealant
I just wanted to share my experience of changing the water inlet unit. It's not difficult changing the part out. it was difficult finding it. If anyone needs help with it you'll have to google part number 55351896. just enter that number in google but make sure you order o ring also and that part number is 13131733. a couple helpful ideas is to use a turkey baster to suck all coolant out of surge tank. then when you disconnect radiator hose hold it up and try to turkey baste as much out as you can. unless you don't mind a lot of coolant all over. then disconnect the other two hoses. tou'll need an 8mm socket unless you have star sockets. use those for sure.The reason I needed sealant is because that darn thing would not seal properly against engine block. there was one point at top middle that coolant was seeping out. Not alot but it would only get worse in my mind. And there's not enough room to apply gasket maker without it smearing onto the o ring. So I bought jb weld epoxy. The black and yelloe tube. So far so good. I seen the thread of Dsaturn about flex seal tape. That might work as well. Less mess. Anyways, I know I ask a lot of questions in these forums but i love working on this darn car. But I like getting it right! So thank you to all those that help and please stay patient with me. I don't know how to post things all the time. Especially pics
Sealant ?? ... Or NOT ? Rickw123 Vue Tech 3 10-18-2015 05:25 PM
radiator sealant? ToledoEngineer S-Series General 13 09-07-2006 05:34 PM
Anyone do their own oil cooler sealant? s3nfo L-Series Tech 1 02-13-2006 06:24 PM
A/C fix using sealant kit angusW S-Series General 2 09-15-2005 04:47 PM
Sealant-Oil Pan? 91SL2 Miscellaneous Tech 2 10-15-2002 11:36 AM
