Old 07-08-2019, 08:33 PM   #1
SuperCookie
SuperCookie is on a distinguished road
Default “Overheating” part 3
Ok third times the charm. hopefully. I bought a new coolant tank cap. And i did a stress test like last time. again around 220F coolant came gushing out of the cap. the needle never got past the middle of the gauge. here is a link to a video of it overheating. I honestly don’t know what to do. I have done the intake coolant fix and bought a new cap. And for the guy who keeps saying “is the recirc line flowing” please post a picture of which line that is.
2001 Yellow Special edition SC2 (not the bumble bee)
Add to SuperCookie's Reputation
Rate the quality of this post and help SuperCookie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SuperCookie is offline   Reply With Quote
Old 07-08-2019, 08:43 PM   #2
Default Re: “Overheating” part 3
Is the coolant container original or replacement? If replacement, maybe not enough threads or something is mismatched between the cap and threaded portion.....
Old 07-08-2019, 08:46 PM   #3
SuperCookie
original
Old 07-08-2019, 09:24 PM   #4
Pressure test the cooling system. New cap in place then the surge tank may be cracked.
Add to ssicarman's Reputation
Old 07-08-2019, 10:50 PM   #5
billr
Here, it is the one with a red arrow pointing to it. Dis-connect from the nipple on the reservoir and see if it flows coolant; post a picture/video if in doubt about how much it is flowing.
http://www.saturnfans.com/forums/att...8&d=1553619577
Add to billr's Reputation
Old 07-09-2019, 03:25 PM   #6
Keblar
Keblar is on a distinguished road
If you got a cheap replacement cap you could still be losing pressure at the reservoir. I've found many of the aftermarket Res caps to be absolute garbage. The threads don't match properly or are too deep to seal. When my original failed I got a cheap one that failed at the center, not the threads, within a year. I went through a pointless return at Advanced Zone only to find 2 "different" aftermarket models were probably the same when the threads wouldn't seat.
Have since had solid experience with:
https://www.amazon.com/ACDelco-RC87-...gateway&sr=8-1
2002 SL2 305k + Miles
Add to Keblar's Reputation
Rate the quality of this post and help Keblar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keblar is offline   Reply With Quote
Old 07-19-2019, 08:51 PM   #7
billr
So, did you check the recirc line? How much does it flow? If you have not done that yet, we are still stumbling around here in "part 3"; no use looking at the "part 4" thread...
How about the pressure-test on the cap and cooling system, do they both hold at least 15 psi?
Need part number or name for this part - 2002 Saturn SL1 nxne75 S-Series General 2 10-14-2017 12:15 AM
Name this part and part number (2007 Ion-2) Swat ss Ion Tech 4 04-04-2014 11:15 PM
flex pipe exhaust part or part number? blaisedaddy Astra General 5 10-18-2012 07:14 AM
How to get the part #s for any part from the Trademotion SaturnParts website dbsanfte S-Series Tech 2 06-01-2012 04:56 PM
2007 Ion: Looking for a Part Number (and maybe the part) fosgate3 Ion Tech 2 06-05-2007 09:03 PM
