Old 02-10-2019, 02:57 PM   #1
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
Default Fuel Filter Bracket Bolts
I have an ’01 SC2 and plan to change the fuel filter when I have nice weather. The filter was last changed at the dealer @ 13 years ago. I was wondering help much luck everyone here had at removing these 2 bracket bolts without breaking them. Today I used a heat gun to help bend the plastic tube from my can of WD40. I was able to spray a good amount in the larger hole towards where the 2 bolts come through on the other side. I will give them a week to soak. Hopefully I can loosen them without snapping them. Has anyone else tried this, or have any tips on removing these bracket bolts? Thanks in advance!
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Old 02-10-2019, 03:31 PM   #2
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Default Re: Fuel Filter Bracket Bolts
I recently watched the RichPin video and he greased his bolts ten years ago after doing the first fuel filter change. They came out for him with no trouble. He knows how they snap easily. I like your soaking them with WD-40 method.
I wonder if there’s a safe way to heat them up? ...like pressing a soldering iron tip to the heads.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 02-10-2019, 04:41 PM   #3
Macgyver
In the salt belt, those just snap right off. There's no amount of penetrant that will save you here and using heat would be dangerous near fuel.
I usually just snap the heads off to remove the plastic shroud and change the filter. I then shoot in self tapping stainless screws near it's original location.
Add to Macgyver's Reputation
Old 02-10-2019, 05:43 PM   #4
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
Mine busted. I drilled and tapped for SAE bolts. They have been installed with anti-seize.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 02-10-2019, 09:23 PM   #5
termite
termite's Avatar
Well I guess if they break, I may drill holes and use those plastic rivets with the center you can push in to lock in place.
Old 02-14-2019, 08:34 AM   #6
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
On a Saturn SL1, it is unnecessary to remove the 2 bolts that hold the bracket in place for the fuel pressure regulator. You simply squeeze and remove the 2 quick release plastic fasteners to remove the front and back fuel line from the fuel pressure regulator and then pull out the fuel pressure regulator toward the back of the car.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline   Reply With Quote
Old 02-14-2019, 09:30 AM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
Using WD40 as a penetrant oil is foisting the largest Internet Rumor in the history of the Amazing Internet
Add to bumpdraft's Reputation
Old 02-14-2019, 11:06 AM   #8
^ ^ ^ Yeah, that is just good WD40 marketing. I don't have WD40 any more as I seldom need Water Displacing spray
PB Blaster, Kano labs stuff (Kroil, etc) and something else I can never remember the name of (orange can)
It's has been many years since I changed the filter on my SL2, but pretty sure I did not touch the bolts. Just squeezed it out at mentioned here
Old 02-15-2019, 12:12 AM   #9
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
WD-40 is kind of like the duck tape of fluids in a can. It's definitely meant for one thing but people kinda just use it for everything. Lubeication, penatrating fluid, cheap car polish, etc.
97 SL2, auto, 118K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-15-2019, 08:41 AM   #10
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
That's exactly what I did the last time I changed one of these. No big deal so don't freak out when the originals snap.
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 04-20-2019, 07:39 PM   #11
termite
termite's Avatar
Today I had a chance to try to loosen those filter bolts, and I got them out! I put a small socket wrench on them and tapped the handle and got them to budge. Then I kept reversing direction until I got a full turn. Then I slowly backed them out. I cleaned them with a steel wire wheel. I then put copper anti seize in the holes and on the bolts and put them back in. I even put a small amount on the parking brake cable retainer bolt. When putting that bolt back I realized I should have released the brake first because i couldn’t line it back up. So when I get a chance I will tackle replacing the fuel filter.😀
Old 04-20-2019, 07:51 PM   #12
Waiex191
Waiex191's Avatar
That is no fair.
Bryan Cotton
Old 04-20-2019, 08:12 PM   #13
termite
termite's Avatar
Possibly the dealer put anti seize on the bolts back in ‘05, or I was just lucky.
Old 04-20-2019, 09:10 PM   #14
After breaking to many of the bolts trying to replace the fuel filters at work I gave up on that. What I ended up doing was to push the filter out of the bracket using large water pump pliers. Worked and no worries of broken bolts.
Add to ssicarman's Reputation
Old 04-23-2019, 08:07 AM   #15
termite
termite's Avatar
Last Sunday I was able to change out my old fuel filter. I used car ramps to raise the car. The back wheel was a little tricky because the ramp did not fit all the way under due to its height , but I had a jack help hold the back up. I was able to remove the fittings with just my fingers. I then got the filter and bracket out. I don't know how people removed the filter from the bracket while on the car because it was tight to slide off even off the car. I put the new filter on the bracket, and got it reconnected. Glad to be done with that!
Old 04-23-2019, 09:42 AM   #16
Nice! I'm coming up on 150k on what I believe to be the original filter, so I will be doing this relatively soon
Busted bolts on fuel filter bracket for SL1 badger1997 S-Series General 2 11-20-2017 11:59 PM
Fuel Filter Bracket Sat_98SC1 S-Series Tech 3 01-22-2011 12:26 AM
How Do I Remove the Fuel Filter Bracket? rockky S-Series General 2 01-17-2010 10:02 AM
'02 Fuel Filter Bracket Bolt MiSaturn S-Series Tech 2 10-13-2007 09:29 AM
New S-Series Fuel Filter Bracket Bolts cris_thomas S-Series Tech 4 01-05-2005 11:19 AM
