Old 08-05-2017, 08:31 AM   #1
Signmaster
Default Back Up Light Switch - manual transmission
Well it took a lot of years, but it finally went. Just posting for future searches that might help others.
Located on the top of the transmission, and easy to pop in and out. I've seen posts claiming that the battery tray might have to be removed for certain years, but this was not the case for my '95. All I did was remove the intake tube, and that was just to give me a more clear shot. Probably could have done it with the tube in place.
All you need is a 7/8" deep well socket, or any type of wrench that will fit and give clearance. I probably could have done it with a short adjustable wrench.
The part I picked up was from Autozone, part #DR4030. About $18.
Though I suspected the switch due to both lights not working, I pulled the bulbs just to check them. It made me realize that since buying this car new, I've never had to remove a back up light yet. They had a real thick dielectric of some sort, almost like wax. And I was shocked that there are a dual element bulb just like the brake/running lights and others. Both elements light up for the reverse lights, and those little suckers heat up quick.
Old 02-04-2020, 06:34 AM   #2
Signmaster
Default Re: Back Up Light Switch - manual transmission
Well, that switch was short lived! Checked it out after noticing a strange flash from the back. The same symptom shows on a meter as well, temporary contact then resistance ramps up quickly.
Of course it's out of warranty, and of course hard to find locally. So I did find one, this time from Advance Auto, and it was dead out of the box! So they brought another one in, and I finally have back up lights again.
And I confirmed my earlier suspicion. I replaced the switch with nothing more than an adjustable wrench. If a person had a shortish 7/8" combo or ratchet wrench that would probably work also. The 7/8 combo I have is long and would have made it more difficult.
Old 02-04-2020, 11:45 AM   #3
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
The backup lights never worked in my '98. If I short the conductors on the connector to the switch the lights go on. I got a new switch from Rock Auto. Should I get one from the junkyard?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 02-04-2020, 11:59 AM   #4
onlinebiker
The bulbs do get hot when on for extended periods - like aircraft landing lights.
The trick is - they are not supposed to be turned on for extended periods..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-06-2020, 10:04 PM   #5
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
This was one of the easiest repairs I ever did to this car, like literally less than a minute to change. Maybe I got a good one, I changed it 7 years ago and it's still going strong
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
03 vue manual trans back up lamp switch Dbaysa Vue General 0 12-09-2015 09:17 PM
Back Up Light Switch karinhesed86 S-Series General 27 05-02-2010 09:15 PM
Cracked a line while trying to replace the back-up light switch on a 2000 sc1 manual negilum S-Series General 12 07-24-2007 12:19 AM
Back-up Light Switch nick620y Ion Tech 10 07-01-2006 12:41 PM
Back Up Light Switch LoveMySL1s S-Series Tech 8 04-01-2003 04:24 PM
