Old 07-10-2017, 10:18 PM   #1
Dman12ny
Dman12ny is on a distinguished road
1994 SC2
Default 95 head onto a 02 block
I have an engine in the machine shop right now getting built, my guys tells me he needs all new timing componets from the older style heads to make
It work. Does this make sense to anyone? From the swap guide it said nothing about the timing stuff not being compatible just some electronics and the egr. Any help is appreciated. Thanks
Add to Dman12ny's Reputation
Rate the quality of this post and help Dman12ny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dman12ny is offline   Reply With Quote
Old 07-11-2017, 12:09 AM   #2
Default Re: 95 head onto a 02 block
Timing cover and 91-98 complete timing set. This is what you need.
Old 07-11-2017, 12:59 AM   #3
Saturn Night
The 1995 Cylinder head will bolt to the 2002 cylinder block without issue. GM used the same block for all years. Differences are pistons and internal balancing.
The timing cover and timing chain set, as Nuc stated, are different from 1999-2002, as GM changed the cylinder head casting designs.
Old 07-11-2017, 02:02 AM   #4
Dman12ny
1994 SC2
Ahh awesome. Glad I have a 91 DOHC with 17 miles, yes 17 miles (it was in a museum for the last 26 years) I can use the parts out of! Now when putting it into a 97 what issues am I likely to face?
Old 07-11-2017, 08:44 AM   #5
Shoulda left the '91 in the Museum where it belongs
The valve cover bolt pattern is all fubar up compared to '93+
The engine mounting is all fubar compared to '92+ (don't think it even has the top engine mount on the timing cover like '92+)
Can't use the block and ICM without swapping the crank, the timing is fubar compared to '93+
Need an EGR adapter or custom EGR valve (easy to customize it with a drill).
Rest of the car should be fine in a '91-'95.
Old 07-11-2017, 06:38 PM   #6
Saturn Night
Leave that 1991 S-Series in the museum, where it belongs. Hemming's just did an article, last year, and 1991-1992 Saturn S-Series are now considered "antique" status, which means their value is increasing much faster than the value of newer year/models of the S-Series
Old 07-17-2017, 01:30 PM   #7
Dman12ny
1994 SC2
Any timing cover will fit over all the new timing stuff correct?
Old 07-17-2017, 01:42 PM   #8
billr
What? No, it has to be from the correct range of years. And for the engine and head combo you are installing, of course. That was all covered above, so maybe I'm not understanding your question correctly?
Add to billr's Reputation
Old 07-17-2017, 03:22 PM   #9
Dman12ny
1994 SC2
I put the 91 timing cover on and realized no place for the top mount, so my question is would a 92-98 timing cover work? Sorry I should have been more specific.
Old 07-17-2017, 06:06 PM   #10
Yes, and a 97-98 would be the best bet as the oil pump cover has a modified oil hole for the chain. When shopping for a timing cover before installing it replace the oil pump gears and verify the timing cover recess is not all gouged up, must be perfectly smooth if possible. You can use the updated oil pump cover on the earlier timing cover.
Old 07-18-2017, 01:11 AM   #11
Saturn Night
You destroyed a classic, that had only 17 ORIGINAL MILES on it, to rebuild a car that is worth less than the car that was destroyed?
I can't even begin to wrap my head around the logic of this thread, anymore......
Old 07-18-2017, 09:41 AM   #12
I call troll at this point. You can't take even a quick look at a '91 without realizing the mounting is way different let alone pull the strut-mount (not the suspension strut mount...the engine strut-mount, '91's are THAT "wack" lol) off to get the timing cover off.
Lane has the only pictures I can find at the moment of '91 mounts, and they don't even show how they go on the car http://www.evilplastic.com/mounts-a.htm
Old 07-18-2017, 04:01 PM   #13
Dman12ny
1994 SC2
I would never have pulled apart a 91 like that.
It was already done, I saw an ad on craigslist drove 600 miles round trip to pickup the engine, automatic tranny, 4 struts and steering rack that the guy pulled from it for $200! Guy was a moron he popped the valve cover off and cut the timing chain getting metal shavings down into the motor in an effort to pull the head for scrap before I came along. I was going to rebuild this motor and throw it in my Saturn circle track car but after doing my research I learned to stay away from the 91 so instead I used parts off of it. I would have bought the entire car from the guy but he had already cut it into pieces to get it out of the museum and scrapped it
Head gasket? Cracked head / block? Paranoia? reverser S-Series Tech 2 04-16-2014 11:11 PM
'96 head on '99 block? cuff S-Series Tech 5 08-05-2008 01:08 PM
92-93 block 97 head? netsniper S-Series Tech 9 05-15-2007 01:13 PM
2nd gen head, 3rd gen block remedys S-Series Mods 2 06-04-2006 12:45 PM
99 block with 92 head elvinrodr Mods and Performance 6 01-28-2004 09:56 PM
