Old 09-12-2016, 04:42 PM   #1
diablo2070
diablo2070 is on a distinguished road
diablo2070's Avatar
2008 Astra XR
Question Struts and shocks
Hello everybody,
As stated in a previous post, I bought a 2008 Astra XR 3 doors, standard transmission. The car had some problems that i solved. Engine is running fine, but I still have to change those 2 rear coil springs that are broken. The OEM kit (2 rear coil springs) is over CAD$300 before taxes, so I decided to go with Eibach Pro Kit and change them all. I got a very nice deal for 200$! I can't wait to see how it handles with them.
I contacted Eibach concerning the struts and shocks. They told me that the Pro Kit was designed to work with OE spec struts and shocks, but advised me that it would be good to change them as my car has 95000 km (60k miles). I noticed that the easily lean a little bit on every movement (sudden acceleration or braking, or a simple corner turn at a very easy speed), and many other symptoms that the Eibach tech told me.
So now, I'm looking to buy new ones, but after searching for over a week, here and on European websites, it seems to be a little bit complicated to find those front struts, especially if I want to buy them in North America. Rear shocks seems more easy to find. There are Koni out there, Sasch, ACDelco, KYB, and more. That's because they are the same as the Cobalt, from what a dealer told me.
I found in this forum the following information (in bold, the part numbers I need) :
Originally Posted by bdshaffer View Post
Here is how Alldata breaks down the different options.
Shocks/Struts
Front Strut - Manual Trans - Right - Without Sports Chassis #93179397
Front Strut - Manual Trans - Right - With Sports Chassis #93179685
Front Strut - Manual Trans - Left - Without Sport Chassis #93179398
Front Strut - Manual Trans - Left - With Sports Chassis #93179684
Rear Shock Absorber - 2 Door #93178641
Rear Shock Absorber - 4 Door #93178640
On RockAuto, I easily found the rear OEM shocks (#93178641). There are also ACDELCO 530456 {#19295558} which are much cheaper (35$ vs 89$) but I can't find any information about how they compare. There is also the KYB 349043 GR-2 / Excel-G which I heard good things about. I don't know what is the real difference between the OEM 93178641 and 93178640 are different, so I wonder if those aftermarket are more like the first or the second one. If anyone know more about this, your help is welcome.
But then, on RockAuto, they have only 1 type of ACDelco (left 93195924, right 93195925, 90$ each) which is not the same as the numbers in the quote. I have no idea what they are equivalent to. There is also Sasch 313480 and 313478 for 130$ each.
I guess I'm not the first to shop for new struts and shocks for the Astra here. What should I buy ? Is there any other brand / choice I should go with?
Add to diablo2070's Reputation
Rate the quality of this post and help diablo2070 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diablo2070 is offline   Reply With Quote
Old 09-12-2016, 05:56 PM   #2
billysvue
Default Re: Struts and shocks
How's the condition of your swaybar bushings and endlinks( assuming it has them)?
.. Great time to change them , as well, if needed.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 09-12-2016, 10:31 PM   #3
diablo2070
diablo2070's Avatar
2008 Astra XR
I have no idea of their condition but I was advised to change them at the same time so I was planning on buying them. Maybe urethane bushing could improve things a little bit.
Old 09-13-2016, 06:33 AM   #4
billysvue
I went to a offroad truck shop-4wheel Parts- for generic "Energy Suspension"( many sizes to choose from with support clamp/strap and ZERK grease fittings).
I just matched them up to what my Vue has... YOur selection may vary
'17 Suby Forester
Old 09-13-2016, 08:55 AM   #5
diablo2070
diablo2070's Avatar
2008 Astra XR
I will look for that. Thanks for the tip
Best shocks/struts? 64waves L-Series Tech 5 09-02-2014 08:10 PM
Shocks, struts, both or something else?? txaginid Vue General 1 04-09-2010 02:00 PM
LS Shocks or Struts LS2GotJuice L-Series Tech 2 08-27-2007 09:34 PM
02 VUE shocks/struts MAYBEAVUE Vue Tech 5 10-17-2006 01:28 PM
Shocks and Struts? Elementkng20 S-Series Tech 11 09-22-2006 11:07 AM
