Old 04-24-2015, 07:40 PM   #1
SalemCat
SalemCat is a jewel in the roughSalemCat is a jewel in the roughSalemCat is a jewel in the roughSalemCat is a jewel in the rough
Default 1995 1996 1998 Wheel Cover / Hub Cap / Lug Nut Cover / Cap - P/N Part Number ?
Many Saturns thru the 1990's have Wheel Covers that are held on with plastic Lug Nut Covers. These are somewhat fragile, and easy to strip.
I'd like to buy some, if I can get them reasonable (used ok), but to do any real research I need a PART NUMBER.
Does anyone have it ? (Thanks !)
If I can't get them I guess I'll just use some aftermarket covers
I did find this page, but it seems to indicate that 21011331 is just for Aluminum Wheels / Rims
Add to SalemCat's Reputation
Rate the quality of this post and help SalemCat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SalemCat is offline   Reply With Quote
Old 04-24-2015, 07:43 PM   #2
Default Re: 1995 1996 1998 Wheel Cover / Hub Cap / Lug Nut Cover / Cap - P/N Part Number ?
RockAuto sell a decent replacement. OEM would probably be expensive if available.
Old 04-24-2015, 08:56 PM   #3
SalemCat
Thanks !
It seems GM Wheel Lug Nut Cover # 21010626 -Dorman 611-617 Wheel Nut Cover is what I need.
Old 04-24-2015, 09:12 PM   #4
Sounds correct, they are all the same.
Old 04-24-2015, 09:26 PM   #5
Jax_1995_SL1
Jax_1995_SL1 will become famous soon enoughJax_1995_SL1 will become famous soon enough
Jax_1995_SL1's Avatar
Rock Auto is amazing. I confess I stock piled the plastic lug but covers from my local junk yard. I figured they would be obsolete, but looks like Rock Auto has them. I might recommend the $1.45 Gray colored ones by Wagner. The hub caps from my Saturn are gray, not black.
The 5 tabs that hold them in place break too easily.
1995 Saturn SL1 SOHC 5 Speed
Add to Jax_1995_SL1's Reputation
Rate the quality of this post and help Jax_1995_SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jax_1995_SL1 is offline   Reply With Quote
Old 04-25-2015, 12:50 PM   #6
SalemCat
Mine are Gray as well - though I've wondered if they just faded to Gray (but they probably were always gray).
If I replaced them all, Black would look as good as Gray ever did. OR - Home Depot sells Spray Paint.
Old 04-25-2015, 01:28 PM   #7
They come in both grey and black. That's another one of those things I found out the hard way... lol
Pretty sure the alloy hub caps came with grey and the full wheel caps/covers come with black...or maybe it's the other way 'round...
Old 05-18-2017, 07:53 PM   #8
saturnsctwo
just thought I would respond to this old thread. I just painted my steel wheels & I thought I would replaced my lug nut caps with these new replacements which look different from the oem ones. part number: 21010626 http://www.ebay.com/itm/New-Genuine-...NVV0My&vxp=mtr
don't buy these. they don't fit. they screw onto the lug nuts, they fit in the wheel openings, but when installed in the wheel covers they won't screw on because the threads in these caps are in a different place. their up farther in the cap which won't reach the threads on the lug nuts. every parts books give this part number for these same caps, but their all wrong.....
I just used armor-all on the old ones they look fine. the style of the new caps I didn't like that much anyway.....
Old 05-18-2017, 09:37 PM   #9
saturnsctwo
I just seen this listing now. these look like the ones on my car, but according to the listing they won't fit: http://www.ebay.com/itm/GM-Wheel-Lug...3D350805813538
I don't get it what the hell is wrong?
Need part number ASAP! Replacing the valve cover gaskets! megatron Vue Tech 4 11-10-2012 06:45 PM
wheel lug cover Part # hawthorne Vue General 9 08-10-2010 12:19 PM
Cam cover bolt part number? 98dingo S-Series Tech 10 10-01-2008 11:19 PM
1995 SL1 PCM part number Jswimelar S-Series Tech 0 10-09-2006 07:56 PM
cat converter part number/ 1995 SC1 Helimech S-Series Tech 4 12-31-2005 12:24 PM
