Old 11-29-2014, 07:47 PM   #1
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Default High Beams will not stay on after clicked
This just happened tonight. AFAIK, to engage the high beams I pull the lever toward me until it clicks, then I release. The high beams should then stay on by themselves. But now they will only stay on if I hold it. I do still hear the click, but the high beams turn off right away when I release the lever.
My assumption is that one of my high beams is out, and that's why this is happening. If not, I do not know what the problem is and I haven't found any info through searching.
Any thoughts?
bachands is offline   Reply With Quote
Old 11-29-2014, 08:09 PM   #2
Default Re: High Beams will not stay on after clicked
Check the lights, get an observer or flat white wall. If the lights work then suspect the switch.
Old 11-29-2014, 08:16 PM   #3
bachands
With the high beams on, I couldn't tell the difference between the headlights. So it appears that both are working just fine.
Regarding the switch, I believe this function is governed by a relay of some kind. Any possibility the relay is in the UHJB? Or is it definitely part of the multifunction switch itself, which requires me to remove the steering wheel?
Old 11-29-2014, 08:36 PM   #4
It is all in the switch.
Old 11-29-2014, 11:33 PM   #5
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
New switch time. Happens sometimes when you click it, and it the switch for the high beams won't stay engaged so they just click right back off. Seems to be an issue in 1998 and early 1999's. Only ever seen it break in those two years.
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
KingRex is offline   Reply With Quote
Old 11-30-2014, 03:02 PM   #6
bachands
Unfortunately for me and my $$, it appears you are correct. I removed the upper and lower steering column covers to see what was going on.
First off, no frayed wires, no bad contacts, and the connector is in great shape. I followed the wires all the way down to where they connect into something near the brake pedal. Everything looked just fine to me.
While pulling the lever back and forth, I could see behind the switch where the connector was. There is this small "pintle" that moves in and out right next to the connector. But it appears that all the contact actions are occurring inside.....between two plastic halves held together by 3 small screws. Since there's no way I'm getting those screws off without removing the steering wheel, I'll just have to wait until I can afford a new switch.
Oh well......at least my headlamps and turn signals still work.
Old 11-30-2014, 03:33 PM   #7
96-02 fits and they are cheap at the pick and pull. The prepulled JY price is 30-40 so figure the P-N-P will be about 1/2 that.
Old 11-30-2014, 05:45 PM   #8
bachands
Great plan for saving $$, but I just can't stand going to the salvage yards in this weather....way too cold for me to concentrate on what I'm doing.
You want to go there for me? I'll give you $20.
Old 11-30-2014, 06:17 PM   #9
Should have gone last Friday or Saturday or later this week, it will warm up.
Old 07-30-2015, 05:29 AM   #10
bachands
I came across this old thread of mine and decided to conclude it.
I DID fix the problem on the switch. The fix required no special tools really. However, I had to purchase a used one to learn how it works first, so it still cost me some $$.
Below is the post explaining the fix with some pictures:
http://www.saturnfans.com/forums/sho...&postcount=150
Shattered windshield glass gets everywhere
High Beams indicator flickering, cutting DRLs, but no high beams andymcconnell L-Series Tech 6 10-04-2012 10:14 PM
Low beams stay on Smokeater S-Series Tech 3 12-16-2011 12:04 PM
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
Fog lights to stay on when high beams are on Dave19yz S-Series Tech 12 12-26-2007 06:46 PM
