Old 12-01-2014, 12:46 PM   #1
ProbikNYC
ProbikNYC has a spectacular aura aboutProbikNYC has a spectacular aura about
1995 SL
Default ECT sensor with resin tip
Where can I get one??? I dont want that brass replacement. Im conducting a test here and need one.
Thanks
Add to ProbikNYC's Reputation
Rate the quality of this post and help ProbikNYC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProbikNYC is offline   Reply With Quote
Old 12-01-2014, 12:53 PM   #2
Default Re: ECT sensor with resin tip
What kind of test? Maybe we can help you with an alternative. The other thought is to look for an IAT sensor in a JY. I'm guessing those were also plastic originally, and few have been changed or damaged from cracking/water.
Add to billr's Reputation
Old 12-01-2014, 12:54 PM   #3
ssssLOWSL2
ssssLOWSL2 is on a distinguished road
This Delphi one looks like its made of something other than brass P/N: TS10193
Good luck.
Add to ssssLOWSL2's Reputation
Rate the quality of this post and help ssssLOWSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssssLOWSL2 is offline   Reply With Quote
Old 12-01-2014, 01:07 PM   #4
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Intake air temp sensors in the air snorkel are the plastic resin tipped units, Those dont go bad because there not exposed to 200 degree coolant for years.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-01-2014, 01:10 PM   #5
ProbikNYC
1995 SL
I have a spare IAT sensor, is that the same as ECT?
Local JY ECT sensor were all replaced by brass tip units already...
Old 12-01-2014, 01:11 PM   #6
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Yes they are the same part.
CHECK YOUR OIL!
Old 12-01-2014, 01:18 PM   #7
ProbikNYC
1995 SL
thank you guys
Old 12-01-2014, 01:24 PM   #8
ECTS (2-wire/lower for '91-'95), IATS and TTS (automatic trans only) are the same (interchangeable) part. Easiest to get to that's nearly guaranteed to be resin is the IATS as mentioned.
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
ETCS..2000 SL2....Resin or Brass ?? Denis Twosaturn S-Series General 4 01-10-2011 11:11 AM
PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) Donny L-Series Tech 5 02-16-2007 01:21 AM
ECTS brass/resin mleader S-Series General 2 03-03-2005 04:21 PM
