Old 04-23-2014, 04:44 PM   #1
EileenSC2
EileenSC2 is on a distinguished road
Default 98 sc2 downpipe diameter (flex pipe)?
Hi, n00b to the forums.....long time lurker. This place has helped me out of a few binds and saved me some serious money! Especially when my ects went. Stupid me thought my clutch was going.
Anyway on to my issue at hand. My flex pipe is toast. I'm basically running open header. Dumb I know but I'm broke. My downpipe is salvageable so I don't want to buy the whole dp/flex assembly for 90 bucks. I was planning on getting a ten inch section of flex at advance for 30 bucks and clamping it on for now until I can afford to get it welded.
What diameter universal flex pipe should I get? I've read several different sizes so I'm a bit confused. Is the dp and cat the same diameter? I've tried measuring it with a tape, but I don't trust myself.
My car is a 98 sc2 manual without the precat. Cat is original as far as I know. Any advice would be greatly appreciated, thanks
Add to EileenSC2's Reputation
Rate the quality of this post and help EileenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EileenSC2 is offline   Reply With Quote
Old 04-24-2014, 05:38 PM   #2
Default Re: 98 sc2 downpipe diameter (flex pipe)?
Pretty sure it's 2.5in, that's the size Walker use's for their parts at least.
Old 04-24-2014, 11:13 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
I used the ROL 520010 on my '95 DOHC, which is 2" ID.
It looked like this . . .
http://www.saturnfans.com/forums/att...7&d=1285879756
Add to Chazberry's Reputation
Old 04-24-2014, 11:38 PM   #4
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Look at Amazon for "Lawson flex"
First part is "FT",
Second part is diameter, 200 is 2 inch, 225 is 2 and 1/4, etc...
Third is length, 6 is six inch, 8 is eight inch...
Fourth is "N" for neck, adds two inches to each end, hence a 6 inch pipe is ten inches long...
Measure your existing flex pipe length, just the flex part, to get the right length.
Needs to be welded, but a high school or community college Vo-Tec shop will usually do it (and other work too!) for free if you buy the parts...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 04-30-2014, 02:49 AM   #5
EileenSC2
It looked like this . . ]
Thanks, I ended up using the same part. I clamped it on for now and it's much better. I'm going to have a friend weld it in a few weeks. I still have a CEL but it runs way better. Hopefully the weld will take care of that.
File Type: jpg IMG_20140424_151244.jpg (157 Bytes, 22 views)
Need a new catalyic converter, downpipe or flex pipe? Sega|Saturn S-Series Mods 2 06-03-2013 09:33 PM
Flex pipe from downpipe to Catylitic donaldo1954 S-Series Tech 13 10-16-2010 10:25 PM
OBX Downpipe Diameter Phonespider S-Series Mods 14 02-01-2007 12:54 AM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
Downpipe, cat pipe diameter ?? Scyan Miscellaneous Tech 3 04-19-2003 01:13 PM
