Old 03-15-2014, 09:28 PM   #1
arick793
arick793 has a spectacular aura aboutarick793 has a spectacular aura about
Default Is the exhaust flex pipe really necessary?
I'm fixing up a 2000 SL1. The flex tubing between the manifold down pipe and the cat is completely gone. I'm thinking about replacing it with a straight pipe for a few months. Any particular reason that I should avoid doing this?
Add to arick793's Reputation
Rate the quality of this post and help arick793 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
arick793 is offline   Reply With Quote
Old 03-15-2014, 09:39 PM   #2
Default Re: Is the exhaust flex pipe really necessary?
It'll rattle, bang around and break the exhaust system somewhere along the line...probably in a far more annoying and expensive place than a $30 flex pipe.
I don't remember if it's 2in there: http://shop.advanceautoparts.com/p/r...Term=flex+pipe
or 2.25in: http://shop.advanceautoparts.com/p/r...Term=flex+pipe
Old 03-15-2014, 09:57 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
I used the Rol 520010 on my '95 DOHC, which is 2" ID.
I regretted not replacing the whole down-pipe/flex ass'y.
Add to Chazberry's Reputation
Old 03-15-2014, 11:12 PM   #4
SL19302
SL19302's Avatar
2002 SL1
The flex pipe needs to be in place for engine/transaxle movement, Installing a straight pipe in its place will crack the flange where the pipe bolts to the manifold or the flange at the Converter.
CHECK YOUR OIL!
Add to SL19302's Reputation
SL2 Exhaust (Flex Pipe) leak alsiroc S-Series Tech 9 10-27-2014 09:16 PM
Exhaust Flex Pipe richpin06 S-Series Tech 73 10-07-2011 09:18 PM
something is leaking onto the flex pipe in my exhaust 96sl1daily S-Series General 6 04-11-2011 12:32 PM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
Exhaust Flex Pipe Questions joshjani S-Series Tech 18 04-10-2005 04:41 PM
