Old 02-09-2014, 04:50 AM   #1
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
Default Pulling only a Tow/Car Dolly (Nothing on it) with a SL1?
So I have been thinking about getting a Tow/Car Dolly for a while to help move around cars and such (moving cars was one of the BIG reasons I got the 3.5 in my VUE instead of the 2.2)
The Cost of the Trip: Chicago to OKC (There & Back) Is:
SL
1670miles @ 30mpg- 56 gallons x $3.5 per gallon= $196
Vue
1670miles @ 20MPG- 83.5 gallons x $3.5 per gallon= $292.25
I am wanting to get a Southern Trailer due to it not having the rust and such that is all over ALL used trailers up here.....
The trailers weigh anywhere from 450 lbs.-551 lbs......
So what are your thoughts about having the SL1 pull the trailer back from the South, bare bones with nothing on it, tires let out as mastertow says to get the "best" trailer for the $$$
Thanks
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
Old 02-09-2014, 10:39 AM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: Pulling only a Tow/Car Dolly (Nothing on it) with a SL1?
Tow capacity for a SL1 should be 1,000lbs. As long as you don't have a car full of cargo, you should be fine.
Just make sure you leave a little extra braking/following distance.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 02-09-2014, 10:46 AM   #3
anmasher
anmasher's Avatar
Hunt4Steve uses his 94 SC1 (with even less power than yours) to tow a bike and gear all the time - should be just fine.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-09-2014, 11:10 AM   #4
Signmaster
Take the SL1 and save the money. Even the tow dollys on the heavy side aren't that much weight really. People pack their car with 200 lb people and think nothing of the extra weight.
When it comes to empty units, airing down the tires as much as possible within safety is a great idea so +1 on that thought. Without the weight of a car on them they have the directional stability of a stoned jackrabbit on bumpy roads.
Old 02-09-2014, 12:16 PM   #5
westwind999
1999 SW1
Towing it with the SL1 should be no problem. It's likely a lot wider than the car though so you need to think about that for curbs/corners. It will also bounce a lot over bumps/rail road tracks when it's empty, even with some lower tire pressure.
Towing on a dolly proveniebam S-Series Tech 2 05-27-2013 10:51 AM
Madison WI area - anyone have a tow dolly madpogue S-Series General 14 01-25-2012 08:59 AM
3 Mile Tow: Flat, Dolly, Tow Strap? Help! WarszawaScream S-Series General 9 12-16-2009 09:26 AM
curse you hurricane dolly! ajs_saturn S-Series General 9 07-24-2008 10:09 PM
Tow dolly for a 93 vs 2000 SL2 93goldsl2 S-Series Tech 7 09-05-2007 06:44 PM
