Old 12-13-2013, 02:20 AM   #1
Superflywimpy
Superflywimpy is on a distinguished road
Default Replaced rear driver bearing hub. Saturn Vue 2006
So I replaced the driver rear bearing hub. Everything went great on getting it off. No corrosion so as soon as the last bolt came off it just came right off. I had a jack holding the brake assembly. When I was reinstalling the bolts ,when I was torquing the first one. The Dayton socket cracked and I spun the socket over the end of the bolt and round the edges. I managed to get it off. But I want to replace it as well as the others. And I want to torque to spec. I read somewhere that the bolts are non reusable and should be replaced anyway. Does anyone have the GM part number for the four mounting bolts for the 2006 Saturn Vue FWD for the rear bearing hub. So I can source them out. Mario
Add to Superflywimpy's Reputation
Rate the quality of this post and help Superflywimpy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Superflywimpy is offline   Reply With Quote
Old 12-13-2013, 11:03 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: Replaced rear driver bearing hub. Saturn Vue 2006
Welcome aboard!
Is it Item 18 here?
http://parts.nalleygmc.com/showAssem...=Wheel+bearing
Add to Chazberry's Reputation
Old 12-13-2013, 01:20 PM   #3
billysvue
Superflywimpy, I believe the correct torque spec on those (4) mounting bolts ....#18....... is 62 ft-lbs.
. WHere did you read they have to be replaced?
I have heard of that with axle nuts from certain vehicles, but these are the bearing mounting bolts you are referring to?
CAn you hammer on the spun socket to get the rounded bolt off?
I used short and deep sockets, 6 point sockets, as well as a 1" extension and a 3" wobble extensiion to be able to get my torque wrench in to do the same job, presently,,,,,,,,, wrapping it up after I replace a wheel cylinder and put back all the body work I removed to apply undercoating.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-13-2013, 06:02 PM   #4
Superflywimpy
Thanks guys for the fast response. I did manage to get the bolt off and I filed it flat where the rounded edges were and I re installed it with a ratchet driver. As far as where I read where it said where the bolts are non reuseable I can't remember where, but the diagram of the rear wheel hub assembly showed the hub and the four bolts. And the four bolts had parenthesis next to the bolts with diamond marks and at the bottom of the diagram the parenthesis had the words non reusable parts with the diamond mark in the wording. I plan to change out the font bearing assemblies as well and have two new spindle nuts I ordered. As I know these for sure have to be changed out when removed. There were 7 bucks each on Ebay. As far as the torque value being 63 ft pounds I want to make sure that this does not happen again do I ordered a impact 13mm socket since it will be much harder than that POS Dayton socket I used. I'll keep you posted on how it worked out.
Old 12-13-2013, 06:45 PM   #5
Chazberry
Chazberry's Avatar
1995 SW2
I've replaced several front and rear hub assy's and have always reused the bolts and nuts. Good luck doing the fronts. Start spraying the PB Blaster asap. The nuts are 33mm - torque 151 ft. lbs.
Old 12-14-2013, 12:00 AM   #6
far2grumpy
far2grumpy's Avatar
Chuck ... OMG - 33mm and 151 ft. lbs. You must be thinking of wheel drive shaft spindle nut socket and torque.
According to FSM the front hubs require new bolts - rear hubs don't.
I imagine different torque values account for reuse of hardware.
Front hub bolts get 96 ft-lbs and rears get 62 fl-lbs (previously listed by billysvue).
Here are a few extracts re hardware reuse and torque - OP said 2006 Vue so I looked there - but also confirmed same statements and torque for 02-07 Vue.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 12-14-2013, 01:09 AM   #7
Chazberry
Chazberry's Avatar
1995 SW2
I was indeed referring to the spindle nut.
Geezus - I have at least 3 front hubs with re-used bolts!
Probably due to the different number of bolts.
Old 12-20-2013, 08:04 PM   #8
Superflywimpy
Ok, I ordered the bolts from GM and they came today. I removed the two that were rounded off and installed the two new ones and torqued them all to 62 pounds. But I have to say I was scared because it seemed like my torque wrench was never going to hit the mark and click. But they did and now I have peace of mind. I want to thank all you Gentlemen for all your great advise. This was my third Saturn. I bought a 93 SL1 new, 2001 Sl2 and this 2006 Saturn Vue v6 FWD. I was so bummed when they closed shop. I think they were pretty cool cars for the money. I always had great luck with them. Thanks again and Merry Christmas. Mario
Old 12-20-2013, 09:52 PM   #9
Chazberry
Chazberry's Avatar
1995 SW2
Yes - it was a definite bummer when GM threw Saturn under the bus!
Fortunately we still have Saturnfans for support.
You're welcome and same to you Mario!
Old 01-06-2016, 06:04 PM   #10
bbake516
bbake516 is on a distinguished road
Sorry I know this is an old thread but I have a question. I have a 2006 Vue, FWD and am replacing my rear hub assemblies this weekend. Is there a spindle nut on the rear? I am thinking that since I have a fwd as opposed to awd there shouldn't be a spindle am I correct?
Add to bbake516's Reputation
Rate the quality of this post and help bbake516 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbake516 is offline   Reply With Quote
Old 01-07-2016, 08:37 AM   #11
skylanedriver21
skylanedriver21 is on a distinguished road
skylanedriver21's Avatar
You are correct: no spindle nut on the FWD rear hub. I have found that (even in salt encrusted upstate NY) that renting a slide hammer from Autozone is the ticket for getting the rear hubs out. Just make sure that you leave the mounting bolts loosely installed so that the whole brake assembly doesn't come flying out when you (slide) hammer it.
Add to skylanedriver21's Reputation
Rate the quality of this post and help skylanedriver21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skylanedriver21 is offline   Reply With Quote
Old 01-07-2016, 12:34 PM   #12
Chazberry
Chazberry's Avatar
1995 SW2
FYI - for those with the AWD, the rear nut is 29mm.
Old 06-12-2016, 04:21 PM   #13
balexander87
balexander87 is on a distinguished road
Just got done doing the rear hubs on my 08 VUE XR AWD. It's axle nuts were 36mm. It blows my mind the varied reports on the sizing of these nuts.
Add to balexander87's Reputation
Rate the quality of this post and help balexander87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
balexander87 is offline   Reply With Quote
Old 06-12-2016, 05:05 PM   #14
Chazberry
Chazberry's Avatar
1995 SW2
It's 29mm on years '02-07. Major design change in '08.
Old 06-12-2016, 08:13 PM   #15
balexander87
That's true. I guess I figured more of the guts would have been carried over. 29 --> 36 is a big increase.
In any case, perhaps my report specifying year and model will be of use to someone.
Cheers :-)
Driver side rear quarter panel 2006 Vue 2.2L tomcat33 Vue Tech 5 11-27-2018 05:25 PM
Wheel bearing noise 2006 Saturn Vue AWD wisconsin snowf Vue Tech 2 03-03-2011 05:22 PM
2000 Saturn SL2 rear driver side door panel removal spyd4r S-Series Tech 2 03-26-2010 09:04 PM
WTB: 2000 Saturn sc2 Rear bumper and rear driver side quarter panel vextc05 S-Series General 2 11-06-2006 02:17 PM
Saturn in latest Car & Driver (june 2006) unkle bik General Saturn Discussion 11 05-04-2006 09:39 AM
