Old 06-05-2013, 09:25 AM   #1
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
Default 96 Sw cruise
On Friday got my SW1 to SW 2 convert back. I put in the PCM from from a 96 SL2. everything runs great except...
My cruise works fine at the start but some 40-60 miles in the cruise disengages. It will reengage for 1/2 mile then disengage. If I turn the engine off it will work fine for another 50 or so miles.
I have replaced the steering wheel pod, the cruise module, even the clock spring all from a daily driver in good working condition.
I am offically out of ideas. What can I try next.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
Old 06-05-2013, 09:37 AM   #2
Default Re: 96 Sw cruise
Brake switch. There is a section of the brake switch that removes 12v from the cruise enable line and this will drop it out. About the only way to verify this is to monitor the 12v line with a LED test light that will go out with loss of 12v. Replacing the switch is slightly expensive and a bit of a physical challenge as the dash structure is built on top of that switch.
Will a 2002 Steering wheel with cruise work in a 97 with cruise? freelancer1988 S-Series General 7 06-23-2012 11:59 PM
98 SL2 cruise to 96 Sl Saturninin S-Series General 2 09-06-2011 08:44 PM
Cruise on 95 SC2 - Help!! Growser S-Series Tech 4 09-15-2008 06:39 PM
Cruise on a '96 SL? sommerdriver S-Series General 5 01-20-2004 12:56 AM
A Cruise with that VUE UoPMBA Vue General 8 02-18-2002 12:55 PM
