Old 03-29-2013, 07:38 PM   #1
Toastymoose
Toastymoose is on a distinguished road
Default Saturn SL1 2000 issues
Recently I went to get my car repaired, and they came to a conclusion that problem was the starter and the transmission range signal they fixed those problems and as soon as i left the dealership the car wouldnt go above 25 mph, but the rpms would keep going up. The car also slams into reverse ever so often and i though it would be the valve body, but i didnt see anything anywhere about the symptom being not shifting into gears. The reverse slam has been happeing for about 7 months but it happens so rarely that i didnt notice it so much. Im just very curious about what it could be and any help would be appreciated.
Add to Toastymoose's Reputation
Rate the quality of this post and help Toastymoose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Toastymoose is offline   Reply With Quote
Old 03-29-2013, 08:32 PM   #2
Default Re: Saturn SL1 2000 issues
Good chance they didn't adjust the trans switch properly.
Add to madpogue's Reputation
Old 03-29-2013, 08:51 PM   #3
Toastymoose
Could there be another issue other than that?
Old 03-29-2013, 11:50 PM   #4
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
How about the manually shifting? If you put it in '2' does that work for you?
Add to lamping.ap's Reputation
Rate the quality of this post and help lamping.ap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lamping.ap is offline   Reply With Quote
Old 03-31-2013, 04:10 PM   #5
Toastymoose
Do you mean putting it into second gear when the car wont go over 25mph?
Old 03-31-2013, 09:21 PM   #6
codyheil1988
codyheil1988 is on a distinguished road
Its an auto shoulda went manual
Add to codyheil1988's Reputation
Rate the quality of this post and help codyheil1988 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
codyheil1988 is offline   Reply With Quote
Old 03-31-2013, 09:43 PM   #7
el diablo viejo
el diablo viejo's Avatar
1994 SW1
I think he means from being stopped, put shift lever down to 2 and start accelerating. Then manually move the lever to 3 and then D as you keep accelerating. See if you get all the gears that way.
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-01-2013, 09:54 AM   #8
magtec
magtec will become famous soon enough
1995 SW2
take it back and make them fix it.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 04-01-2013, 01:10 PM   #9
Toastymoose
Yeah if I do that I hit all the gears
Old 04-01-2013, 01:31 PM   #10
lamping.ap
If your're going to troubleshoot this yourself, I would verify the range switch has been adjusted properly. Below is the procedure for the adjustment from the FSM. Before loosening the switch-to-case bolts as if you were going to adjust it, just remove the connector and verify continuity with the selector in D. If that's good, disregard the adjustment procedure.
Important: While adjusting the transaxle range switch, always rotate the switch towards the engine to achieve continuity. A diagnostic trouble code DTC P0706 could result if this procedure is not followed.
Important: Digital volt/ohm meter (DVOM) with audible continuity test is preferred. Do not stick the probe in the transaxle range switch terminal hole; use male terminals on the transaxle range switch or faulty readings could occur.
•Place the transaxle in Drive (D). Use an ohmmeter or continuity tester to check for continuity across terminals on the selector switch. Rotate the transaxle range switch from the left fender towards the engine until continuity is achieved.
•Tighten the switch-to-case bolts. After switch-to-case bolts have been tightened, check continuity.
Tighten
Tighten the transaxle range switch-to-case bolts to 14 N·m (10 lb ft).
•Connect the transaxle range switch harness connectors.
•Install the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement in HVAC.
•Using a scan tool, ensure each gear position reads correctly while manually moving through all gears.
Old 04-01-2013, 01:40 PM   #11
Toastymoose
Will try after i get the car back from the transmission shop, can I message you if the problem persists after I try these instructions? Thank you everybody for your help.
Old 04-01-2013, 03:12 PM   #12
lamping.ap
If the car is at the shop why are you trying to fix it? Why won't they fix it? I feel like you're leaving out some info...
I need help with my 2000 Saturn SL2 Overheating issues toddsrams General Saturn Discussion 3 06-13-2016 04:47 PM
2000 Saturn SL (manual) starting issues rajia21 S-Series Tech 5 05-23-2012 05:00 PM
2000 Saturn SC Coupe Overheating issues need help. TDAVENPORT S-Series Tech 8 04-15-2012 10:03 AM
2000 saturn speaker issues dangos L-Series General 2 03-08-2012 03:27 PM
2000 Saturn SL (manual) starting issues rajia21 S-Series Tech 2 01-16-2012 03:35 PM
