Old 12-16-2012, 01:16 PM   #1
bbyers
bbyers is on a distinguished road
Default Is this the correct location of my temp guage? please see pic
this is a picture after car is fully warmed up, its always stays at this location, do i have something that i needs fixed or is this location normal.
2002 saturn SC2 5 speed
Add to bbyers's Reputation
Rate the quality of this post and help bbyers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbyers is offline   Reply With Quote
Old 12-16-2012, 01:49 PM   #2
Pitcher
Pitcher's Avatar
Default Re: Is this the correct location of my temp guage? please see pic
Not quite.
It's usually the Thermostat, but can be the ECTS.
How old is the Thermostat?
Owned 4 other S-Series.
Add to Pitcher's Reputation
Old 12-16-2012, 02:32 PM   #3
bbyers
Originally Posted by Pitcher View Post
Not quite.
im not sure how old the thermostat is, i just got the car and noticed the heats not that great and than noticed the temp guage seems alittle low.
Im not sure what the ECTS is...?
Im getting 36mpg, so i thought maybe the motor was heated up enought and guages in these cars ran low.
Old 12-16-2012, 03:40 PM   #4
bbyers
just called about a new thermostat, but was told by sales person the stant14279 wont fit my car. I thought i read that this is the on to use??? im confussed now.
Old 12-16-2012, 03:57 PM   #5
TXSaturn02
TXSaturn02's Avatar
Many people swear by the stant here, for whatever reason, despite many members reporting issues with it. I went with the thermostat the Autozone guy brought out and, in January, it will be in longer (and more miles) than the original that came with the car. Ultimately, you must make your own decisions.
You must remember that almost all opinions have a bias.
As of 07/25/18: 51,495 Miles
Old 12-16-2012, 04:38 PM   #6
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
Same location for me.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
Old 12-16-2012, 04:49 PM   #7
bbyers
autozone in my area only has the 180 degree.....is that the one your using?
2002 SC2 Manual 166,XXX miles
Old 12-16-2012, 04:54 PM   #8
TXSaturn02
TXSaturn02's Avatar
I can't remember the brand. I do remember it was made in Germany and it came with the entire housing (not just the thermostat). It has worked well - I believe coming on 6 years old now. It was labeled "85" on it - I assume that meant 85 degree celcius which translates to 185. It has worked very well.
Old 12-17-2012, 02:50 AM   #9
mizzly
mizzly is on a distinguished road
1996 SL2
That is where my needle runs and i just changed my thermostat.
Add to mizzly's Reputation
Rate the quality of this post and help mizzly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mizzly is offline   Reply With Quote
Old 12-17-2012, 04:11 AM   #10
Gostlrs
Gostlrs is on a distinguished road
1993 SL2
Love that...You are so correct yet some people can't take it when someone else say's something different....
This seems like a very common issue on these. Mine does it as well but reads below the 1/4 mark. I plan to replace the thermostat & Temp Sensors because mine will raise when at idle but the fans won't turn on. (they work with A/C on though)
IMO if you are going to replace the thermostat why not swap out the temp sensors as well, only cost a few more bucks & the car is already drained to do it. A little preventive maint can go a long way sometimes.
Current Rides
2006 Pontiac Grand Prix
1994 Nissan Hardbody
1994 Mercury Capri XR2 (#350 of 366 Made)
1993 Saturn SL2
Add to Gostlrs's Reputation
Rate the quality of this post and help Gostlrs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gostlrs is offline   Reply With Quote
Old 12-17-2012, 09:59 AM   #11
If you have adequate heat from the heater and it moved quickly to that position then it is normal for the 2000+ Saturn temp gauge.
How these thermostats perform and last is a function of the external environment so what works in Houston Texas may be a dismal failure in Minneapolis.
If you have a 1st gen car the normal point is 1/2 not 1/4. The correct OEM replacement thermostat is the STANT 14279 or the equivalent in setpoint and physical construction from the other sellers.
Saturn 96 model year and newer temperature gauge reading vs. actual temperature as read from the ECTS.
GAGE Reading..........ECTS Temperature..........Event
.....1/4.................................150 F
.....3/8.................................192 F...................T-stat cracks open
.....3/8+................................195 F
.....1/2.................................212 F
.....9/16................................221 F...................Fan ON
.....7/16................................210 F...................Fan OFF coast to 205 F
The installed thermostat is marked as 87 C
Add 1/8 to the gauge reading column to obtain the corresponding gauge indication for Saturn 95 model year and older.
NOTE: 2000+ will read just above 1/4 and this is correct.
Old 12-17-2012, 10:42 AM   #12
If your car is not hard to start and you get decent MPG, your ECTS is probably OK. If you look at the wiring for the ECTS and notice shrink-wrap on it, it probably has been replaced already. If you see electric tape on it, it probably has been replaced but with some kind of mechanical connector that may be trouble in the future.
How to find/replace the ECTS
The Stant 14279 will fit and work (I've had two in my car, a little shy of 50k miles). The first one only lasted 3 years; several others who did the tstat replacement around that time also had earlier than expected failures. Parts stores guys aren't always right. BTW, many of us are using larger oil filters than the OEM one; if you aske the parts stores, they will either say it won't fit or don't know
Since the car is new to you, and you suspect the t-stat, and about 2/3 to 3/4 of the coolant will come out of the car when you replace the tstat anyway... now would be a good time to drain and flush out the system, and refill with a gallon of pure long-life Universal antifreeze and top off with distilled water.
Don't take it to a shop for this work; if you have some basic tools and a garden hose, you can do this yourself in an easy afternoon for about $25 total.
Old 12-17-2012, 11:09 AM   #13
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
For your year, that is on the low end of normal. I would say the thermostat is just tired, if you replaced you would probably get slightly better heat.
The readout on my '00 SW2 was just like yours and when I replaced the stat, the heat got a bit better and the gauge went another few needle lengths toward the middle.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 12-17-2012, 10:46 PM   #14
Just noticed, your car is a 2002 - those came from the factory with the brass tipped ECTS.
Plug in a code reader that can read live data and see what temp is being reported, or put a thermometer in the return stream of the reservoir when the engine is warmed up (careful not to get burned). Many Saturn gauges are inaccurate.
Old 12-18-2012, 12:05 AM   #15
shortchevy
shortchevy is on a distinguished road
my 01 used to run below 1/4 so I changed the t-stat and ects (plastic tipped) now it will sit right where yours is but only at idle. if I drive the car at 70mph for 5 min it will be a little below half. a bad ECTS will be obvious, like a hard start no temp reading (ive gone through 2 in 20,000 now, soldered new plug on both times and applied grease)
Seems like your t-stat is stuck open. not a pressing matter, cheap fix and easy to do. you'll need a 10mm wrench or socket a razor, scotch-brite, or piece of sandpaper and some Vaseline.
get a new t-stat and a (1) jug of dex-cool.
take apart
take out old
clean mating surface with razor or scotch-brite or sandpaper
put in new
put new o-ring in and use the Vaseline to hold it in place
install
top off coolant
DONE!
Add to shortchevy's Reputation
Rate the quality of this post and help shortchevy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shortchevy is offline   Reply With Quote
Correct Temp gauge Reading for 1992 SL2? bountyhunter S-Series Tech 4 02-17-2011 08:49 PM
correct thermostat temp simidrm S-Series General 27 10-24-2006 01:29 AM
97 Temp guage sensor location sokinasr S-Series Tech 1 08-22-2006 09:36 AM
HELP!! Glow face guage install! Temp guage error! SpeedySL1 Suggestion Box 2 04-01-2004 04:05 PM
What is the correct temp guage reading? JDub99SL2 Miscellaneous Tech 5 11-03-2003 02:45 AM
