Old 06-20-2012, 10:19 PM   #1
freelancer1988
freelancer1988 is on a distinguished road
freelancer1988's Avatar
1997 SL1
Question Will a 2002 Steering wheel with cruise work in a 97 with cruise?
I just got a 1997 SL1 with all the options. (including cruise) I was wondering if anyone swapped in a 3rd gen steering wheel? I like the 3rd gen wheel better (mainly because the horn is in the middle.) I was just wondering if anyone had really good pictures of the cruise connectors and airbag connectors. I was hoping it is a simple plug and play swap. lol.
Add to freelancer1988's Reputation
Rate the quality of this post and help freelancer1988 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freelancer1988 is offline   Reply With Quote
Old 06-20-2012, 11:44 PM   #2
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Default Re: Will a 2002 Steering wheel with cruise work in a 97 with cruise?
If i remember correctly It is the same module, HOWEVER i don't think the cruise is the same, I could be wrong. It's easier to cut a small hole with an utility knife and mount the external switch.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 06-21-2012, 09:12 AM   #3
I think it will bolt up, but won't be plug and play. Horn is different, I think, but with a little splicing can be made to work (ditto w cruise). You will also want to do some research on the airbag modules, dunno if 3rd gen was different.
Spending a little time at the JY will let you know about the connectors
Old 06-21-2012, 10:59 AM   #4
freelancer1988
1997 SL1
I was wondering if the clock spring would plug up and then make most things plug-n-play. I will most likely go out and get one and see what I need to do, but I was hoping someone tackled this before me, lol.
Old 06-21-2012, 06:48 PM   #5
bluesl2
bluesl2's Avatar
The 1997 and the third generation s cars have different steering shafts. The 97 has 2 flats on it(keyed so to speak) and the 3rd generations have a splined shaft,also keyed, I don't think it will work. Maybe if you changed the whole shaft, but that's more work than I'd do.
Add to bluesl2's Reputation
Old 06-22-2012, 09:31 AM   #6
Originally Posted by bluesl2 View Post
The 1997 and the third generation s cars have different steering shafts. The 97 has 2 flats on it(keyed so to speak) .
Thanks for the correction.
I vaguely recall having this being mentioned before (now that you mentioned it) but found some threads that implied otherwise. I thought I saw something on a saturnwiki but couldn't find it just now
Interestingly, it looks like Saturn removed the threaded holes for pullers sometime in 2000
http://www.saturnfans.com/forums/sho....php?t=109919#
http://www.saturnfans.com/forums/sho...=64627&page=2#
geez, I'm getting old and forgetful. We had this conversation a few years ago
http://www.saturnfans.com/forums/sho...33&postcount=6
Old 06-23-2012, 11:54 PM   #7
freelancer1988
1997 SL1
Neat information. I will be going to my local pull-a-part soon, so I will try to swap them around there and see what happens. Thanks for all the help. I figured they would of changed the steering columns some to make it not work.
Old 06-23-2012, 11:59 PM   #8
The thing to do some serious research on is the air bag. Your '97 car has the first-generation high-power air bags. The gen-3 wheel will have a second-generation de-powered air bag. You need to determine whether your SDM will fire that air bag properly.
Add to madpogue's Reputation
does the steering wheel with cruise control from L200 fit on a SL2? saturn95 S-Series General 5 08-25-2010 02:01 PM
1992 SL2 Steering wheel cruise control swap CheapSL2 S-Series Tech 4 04-21-2010 12:46 PM
steering wheel / cruise swap question blue92 S-Series Tech 7 07-21-2008 07:18 PM
Cruise and Horn do not work on Steering wheel..need help dschwer S-Series General 5 03-03-2006 12:07 PM
how to install cruise w/out a new steering wheel 00/02 basmoq S-Series General 1 08-12-2005 09:22 PM
