Old 06-10-2012, 12:01 PM   #1
msmay0
msmay0 is on a distinguished road
Default Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed
Already started this yesterday.
I had one heck of a time taking of the engine without the trans. Based on the difficulty of it I'm unsure if I can put back the unit as is. I may have to take off the trans and mate it before dropping.
So I'm curious if you guys did something specific to freeup space/leverage to remove the engine without the trans. Or is it mandatory to remove both for engine swap?
Btw to gain clearance I removed the crank pulley. But the trans/cv remain intact.
Lmk if you have pointers or if trans has to go out aswell.
And if it does it the cv a snap on? I mean push/pull snap onto the trans?
Thanks
Add to msmay0's Reputation
Rate the quality of this post and help msmay0 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
msmay0 is offline   Reply With Quote
Old 06-10-2012, 12:29 PM   #2
Default Re: Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-spee
With a manual trans it is easier to pull the engine with the trans. Certainly easier to get it all back in with the engine and trans together.
Add to ssicarman's Reputation
Old 06-10-2012, 01:01 PM   #3
shaggydavid
shaggydavid is on a distinguished road
shaggydavid's Avatar
1997 SW2
i pulled the engine on a 5 spd by taking off the harmonic ballancer pully taking the bolts out of the bottom trans mount, the top engine mount (duh), bottom engine mount bracket. then all the other steps coming up to seperation. with the engine held by a cherry picker, turn the engine alittle, brace the trans with jack stand, take out the 4 engine to trans bolts and seperate. you will want the engine to slant back alittle as you pull it. i know it sounds complicated, but if you can pull one from an auto, then you can do this one too. P.S. i used this procedure on my auto to man swap.
Add to shaggydavid's Reputation
Rate the quality of this post and help shaggydavid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shaggydavid is offline   Reply With Quote
Old 06-10-2012, 02:40 PM   #4
msmay0
Uh I pulled it out already. I was asking about putting it back cuz I had a hard time taking it out so I don't know if Ill have room to match the clutch with the input shaft and put it in too.
I guess I'm taking off the trans.
Does the cv just snaps onto the trans?
Old 06-10-2012, 03:14 PM   #5
shaggydavid
1997 SW2
it works backward, drop in the clutch side droped down a bit. you will probally have to turn the flywheel alittle to line up the slpines.
Old 06-10-2012, 05:01 PM   #6
sajor
sajor is on a distinguished road
Yep, I did it that way. When you put it back in, tilt the clutch side down, and make sure you remove the upper engine mount, I had a heck of a time putting the engine back in with the thing still on the frame. It has a couple of screws in the wheel well. Kept struggling for just a few mm of clearance
Add to sajor's Reputation
Rate the quality of this post and help sajor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sajor is offline   Reply With Quote
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
engine/transmission swap in under 10hrs fetchitfido S-Series Tech 1 12-16-2011 10:16 AM
96 SL1 - 5 speed engine swap advice needed casterman S-Series Tech 8 04-04-2008 08:19 PM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
