Old 06-13-2011, 01:27 AM   #1
diplomat1
diplomat1 is on a distinguished road
diplomat1's Avatar
Default Why does my car start with high rpm's everytime?
Hello there. I have a 94 saturn sl2 and i wanted to know the reason it starts and goes to high rpm's (round 2000) then drops to 1300 until it warms up? It only does it when i start the car when its sitting over night but when i use the car and get out and get something from the store and come back and start the car it doesnt do it. What can it be? I replaced the thermostat couple of months ago so i dont think thats it. Thanks guys
EDIT: I algo have code 26 if that matters.
Prince
diplomat1 is offline   Reply With Quote
Old 06-13-2011, 01:42 AM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: Why does my car start with high rpm's everytime?
That's normal.
colonelhogan44 is offline   Reply With Quote
Old 06-13-2011, 03:18 AM   #3
desertrat
desertrat is on a distinguished road
2000 SC1
That's about normal for lots of cars. It has to do with cold start. As it warms up, or goes through it's cycle, or loop, the RPMs start dropping. It checks outside temp and elevation, too I think. Hope this helps. I always let my car warm up for about 5 minutes before I start driving. Gives me time to take off my work shoes at work and switch to my normal shoes.
desertrat is offline   Reply With Quote
Old 06-13-2011, 09:18 AM   #4
A high idle when cold warms your engine more quickly, to get it into closed loop more quickly for fuel economy.
My Honda CRX had a cold idle of 3,000+ rpm; I almost took it back to the dealership, before I read the info on the emissions sticker under the hood - said 3k~3.5k was normal cold idle
Some reading on your 26 if you are inclined
http://www.saturnfans.com/forums/showthread.php?t=284
edit: just noticed your warmed up idle is 1300 - that is high, I think normal is 800~950. Has your ECTS been replaced, and where do your engine temps sit at when the engine is warm? Last hrottle body and IAC cleaning?
Old 06-13-2011, 09:46 AM   #5
PlasticCarsRock
PlasticCarsRock's Avatar
OP said it's 1300 until warmed up. That's normal. Idle can be as low as 750 with an auto in gear. As long as it's over 700 and less than 1000 when warmed up, don't worry about it (there's a more specific range, if you go by the FSM, but analog tachometers like yours are not all that accurate, so I wouldn't be worried about seeing the exact number the FSM specs, without a more accurate way to determine rpm).
Should work on that code 26, though...
Old 06-13-2011, 10:57 AM   #6
Thanks, skimming posts and missed the "until it's warmed up" part.
My tach is off by 50 rpm high
Old 06-14-2011, 03:03 PM   #7
diplomat1
diplomat1's Avatar
So i did some research and found out that alot of people fixed this problem by replacing the egr valve solenoid/egr valve/evap soleinold. My car is a 94 sl2 with an ELECTRIC egr ( no soleinoid i believe). Will a bad egr valve cause code 26 to go off? The code come and goes. Only comes when the car is warm and sitting idle for like 5 mins. When the car moves the light goes away.Will the evap solenoid fix this code? DO i even have that? Thanks guys
Prince
Old 06-14-2011, 04:31 PM   #8
What's idle rpm when its fully warmed up? Normal cold start idle would be closer to 1200rpm and 800-900rpm after warming up.
Old 06-14-2011, 09:24 PM   #9
diplomat1
diplomat1's Avatar
Exactly what i thought. Usually before this problem happened it went up to around 1500 when i started the car then go to 1300-1200 until warmed at 700-800. Now it goes straight up to 1900 rpm's the gradually goes down until the idle it around 700-800 fully warmed. It just happened when i start it after an over night or a couple of hours pass. Thanks
Prince
Old 06-14-2011, 10:21 PM   #10
off-track
off-track's Avatar
Check out the Richpin videos on youtube for both TB and EGR cleaning. If you do both there's a 99% chance it will go away. Easy to do and something you can do in maybe an hour or so (the first time).
Purchased 114k 10/07
Added OEM CC
Old 06-15-2011, 12:02 AM   #11
diplomat1
diplomat1's Avatar
Cleaned both already 100% bout couple of months ago? I replaced plugs and wires but i think the valve cover where the plugs go i think is leaking and puttin oil on the plugs. Could that do anything?
Prince
Old 06-15-2011, 03:32 AM   #12
Oil would introduce misfiring and lower idle. A vacuum leak would allow more air to raise rpm across the entire rpm band. A leaking/sticking egr valve allows exhaust gases that reduces rpm.
A worn out throttle position sensor can raise rpm until the engine is shut off and restarted. Usually this occurs after warm up while driving and restarting drops idle speed back. Only a replacement tps will cure erratic high idling. Whether this corrects your situation is debatable.
Checking for intake manifold gasket leaks would be difficult as a cold engine will expand parts that can seal off vacuum leaks..............
Old 06-19-2011, 04:23 PM   #13
diplomat1
diplomat1's Avatar
UPDATE: So i replaced the TPS sensor and still same issue. Here is a video of when i start the car and how high the rpm's go (in this video the car was a little warmed up from the drive before so thats why it fell low so quick)
http://www.youtube.com/watch?v=6ZUR1aXdggQ
You see how it hits around 2k rpms i havent seen the car ever do this ever before a couple of weeks ago. Here is how i thought the car should start.
http://www.youtube.com/watch?v=iJUgYzJMa-U
I know the rpm's feel down quick (cause it was warmed up) but before even if the car was cold from sitting overnight, it would still start up at the same rpm's it started up when the car was warmed. Please any help would be appreciated. Also i pulled a spark plug out and the plug was SOAKED in oil. Does that mean i need a new valve cover? Thanks
Prince
Old 06-19-2011, 05:48 PM   #14
Those two videos show a normal start up. Since the rpm hits a peak of 2k or less and quickly drops down to below 1k its presumed the engine was warm each time. There's nothing to be concerned about. Normal cold engine starts might have the initial rpm high but if it quickly drops down to 1200-1500rpm while warming up, this is normal behavior.
Oil soaked plugs means the valve cover needs new plug gaskets to seal around the cover to engine block and keep oil from seeping into the plug area. Next time you pull any plug, look into the plug opening and check for oil covering the lower part of the plug. Oil covering the plugs before removing them is a valve cover gasket leak.
Old 06-20-2011, 12:29 AM   #15
diplomat1
diplomat1's Avatar
Yea thats what i said it was already a little warmed up fdryer but my question is in the first video see how it goes to 2000 rpm's when started. it never did that until lately my questions is why. Is that normal? Also today i started my car (it was warm already i ran in the store for a second) and the idle went really low around 500 but when i turned the car off and turned it back on it was back to around 700-800. Any idea why?
Prince
Old 06-20-2011, 12:54 AM   #16
You may be obsessing a little more than necessary as nothing seems out of the ordinary. The car starts and runs without staying at high rpm's unless the engine is cold and then its only running around 1200rpm until the engine warms up. A little higher rpm and dropping immediately won't harm the engine.
If you want to go further then start checking fuel pressure for possible leaks in any injector (not likely) or fuel pressure regulator (not likely). Read all you can about electronic fuel injection and how each sensor sends data to the pcm to act on it to develop air fuel mixtures. Then when you're armed with all the information, determine when a sensor or two changes the behavior of EFI systems. By the time you absorb all the information and become experienced you'll have moved on to other cars...............................
Old 06-21-2011, 11:14 PM   #17
rowdydog
rowdydog has a spectacular aura aboutrowdydog has a spectacular aura about
rowdydog's Avatar
2005 ION Red Line
try cleaning the IAC, mine was carboned up its below the tps
rowdydog is offline   Reply With Quote
Old 06-21-2011, 11:32 PM   #18
Rand0m0sityxX
Rand0m0sityxX is on a distinguished road
If its just start up I think it's normal.
Mine (a '99 sl2) start up used to go up to 3,000 rpms then drop to 1,000 rpm once warmed. BUT it also jumped around when I go to stop and stuff on the road.
I haven't figured out what it is tho, my husband unplugged the Idle Air Control Valve, which I don't know if its good or not. I want to say its the EGR or something like that but he won't listen to me because they're "expensive".
1999 Saturn SL2- Maria- 134,000
Rand0m0sityxX is offline   Reply With Quote
Old 09-20-2014, 04:49 PM   #19
98 Rider
98 Rider is on a distinguished road
My daughters 98 Saturn's rpm would always raise up to 2500 rpm and drop down to 1100 at start up. No matter if the engine is cold or hot, same thing. I replaced the IAC valve. This is the idle air control valve. Problem solved. I got the iac valve from Ebay for $10 bucks brand new. For those of you who are experiencing this same problem, replace your iac valve. For us the iac valve is located at the rear front portion of the throttle body facing the firewall. Two torx head screws which are a little tricky to get at. Be sure to place a rag under the throttle body in case you drop the screw it will fall on the rag. Other wise you will never find it if you drop it without something to catch it. Clean out the throttle body with throttle body spay cleaner. You can purchase a can at any automotive parts store. After you remove the old iac valve, then clean the throttle body. Again, place an old rag under the throttle body to catch the dirty liquid that will drip out while spraying. You will see black liquid drip out, that is the carbon that had build up over time. Make sure that you spray the inside of the throttle body real good. Especially around the round throttle plate inside the throttle body. Keep spraying and wiping with a clean rag until you don't see anymore of the black carbon on the rag. Then install the new iac valve. Before you start the job, disconnect your negative battery terminal. Good luck, Tommy.
98 Rider is offline   Reply With Quote
High RPM's RedRockerL300 Astra Tech 9 05-23-2011 04:37 PM
High RPM's on 2007 ION 3 2.4 jarceri Ion Tech 12 12-07-2010 05:46 PM
93 SL2 still high RPM's boatmoter S-Series Tech 20 11-23-2008 12:49 AM
intermitting high rpm's boatmoter S-Series Tech 3 09-03-2008 08:09 PM
06 RL does not start everytime Esonn33046 Vue Red Line 4 04-25-2007 01:37 PM
