Old 04-12-2011, 12:10 AM   #1
tgferg67global
tgferg67global will become famous soon enoughtgferg67global will become famous soon enough
tgferg67global's Avatar
Default Radiator tank crack fix with soldering iron
I saw this method used by others so I thought I would try it. No leaks yet.
Clean the area.
Cut a donor strip from the tank.
Melt a valley along the crack with the tip of the soldering iron.
Melt the donor material into the crack.
Add to tgferg67global's Reputation
Rate the quality of this post and help tgferg67global reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgferg67global is offline   Reply With Quote
Old 04-12-2011, 12:42 AM   #2
t&m
t&m is on a distinguished road
Default Re: Radiator tank crack fix with soldering iron
Interesting idea, thanks for the writeup. Let us know how it holds up.
Add to t&m's Reputation
Rate the quality of this post and help t&m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
t&m is offline   Reply With Quote
Old 04-12-2011, 09:43 AM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
What "others" have you seen doing this?
I've been an owner now since 1997 and I have never seen this method used at all...
in 99% of most cases- replacing the radiator is the best fix for this; but if you have fixed it and it holds up, this would be an unorthodox way to keep the radiator going in the car.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 04-12-2011, 09:56 AM   #4
Very interesting. I've never seen it before, either, though I think about it every time I go the Harbor Freight and see this "plastic welding" tool they have.
Someone researched the type of plastic used in the end caps and used a particular epoxy designed for that type of plastic
Someone else (hein?) uses a piece of lexan and regular epoxy and puts a patch over that area
If I ever have such a crack, I may use all the methods - melt it shut and coat it with that special epoxy, then slap a plastic patch onto it.
Old 04-12-2011, 10:01 AM   #5
tgferg67global
http://www.ehow.com/how_4822270_repa...radiators.html
Old 04-12-2011, 10:26 AM   #6
sousa632
sousa632 is on a distinguished road
sousa632's Avatar
1995 SW2
When my radiator burst, I did the correct repair...... I replaced it. That I would imagine would only be a temporary 'fix' till you have the money to replace it. The plastic is weakened in that area and it's all in due time that it will fail again with the temperature fluctuation and (slight)pressure. I'd like to be proved wrong though.
John
96 Tbird 4.6L, 95 Saturn SW2
Add to sousa632's Reputation
Rate the quality of this post and help sousa632 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sousa632 is offline   Reply With Quote
Old 04-12-2011, 10:33 AM   #7
tgferg67global
Maybe it will, maybe it won't. Maybe you will be replacing your new radiator soon as many have because it is not of the same quality as the OEM.
If it fails it would most likely leak slowly as it did before. Don't forget the repair is now part of the tank.
Old 04-12-2011, 10:43 AM   #8
I gotta wonder, with the typical location/shape of that crack, if it's not due in part to the presence of the cooler line, and the fact that the powertrain moves relative to the body. I'm thinking a fix like this would work better if it were recommissioned into a 5-speed car, without that influence.
Add to madpogue's Reputation
Old 04-12-2011, 10:56 AM   #9
tgferg67global
Thats a good point, but the transmission cooler lines are flexible hoses and the crack is always at the top fitting and not the bottom one.
Old 04-12-2011, 11:06 AM   #10
tgferg67global
http://www.urethanesupply.com/radiator.php
Old 04-12-2011, 11:21 AM   #11
2NDSOUT
2NDSOUT's Avatar
1999 SL
When you said "Other People that you have seen doing this"; I immediately thought that there were others on saturnfans that had done a repair like this...
Now I see the links from E-how and other websites that have mentioned this--
More power to you that you were able to repair, and I hope that it holds up, but in this instance; I would rather replace it with a new unit.
When it comes to anything that is related to the coolant system (radiator, water pump, etc.) or electrical (battery, starter, etc.) I feel it is always better to replace with a new item rather then trying to fix the broken item...
just my thoughts--- ymmv.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 04-12-2011, 11:41 AM   #12
TXSaturn02
TXSaturn02's Avatar
Thanks for your post. There are a lot of smart people on this site, but sometimes people think that their way is the only way.
Keep us posted.
New owner report of 08/08/19: 234,408 Miles
As of 07/25/18: 51,495 Miles
Old 04-12-2011, 11:43 AM   #13
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Delphi (OEM, supposedly) radiators can be had for around $80 shipped. I am due for this repair myself.
My concern is that even if you repaired that particular crack to be as good as new, that just may mean that the radiator's second most weakest point will soon give. For example, in my case, the radiator likely has over 160k miles on it.
If you want to experiment, great, let us know how it goes, but for $80, I'd rather put an entirely new radiator in and forget it. But if you have the time but not a lot of money, or if you are dumping the car soon, your way might be the way to go.
Add to Baron5867's Reputation
Rate the quality of this post and help Baron5867 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Baron5867 is offline   Reply With Quote
Old 04-12-2011, 11:50 AM   #14
tgferg67global
My car had a slow leak in the area since 2004, 115000 miles ago. Car has 215k now. I added a little fluid every few years. The leak never got any worse until I recently replaced the thermostat. Considering the above scenario I am fairly confident it's going to hold. If the area was under such stress it would have degraded over the years.
Old 04-12-2011, 01:47 PM   #15
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
Now that you have at least a working solution I would use the time looking for a great price on a great replacement. That way you have it staged if the current does not last as long as you hoped.
Add to ehunter's Reputation
Old 04-12-2011, 01:58 PM   #16
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
I've done this a number of times on different S-Series. All I can say is, if you're interested in doing it, go and try it. If not, get a new radiator.
The tanks actually have quite a bit of fiberglass in them. The repairs I did surprisingly held up quite a while though. But I would say it takes practice to get right (and I think most people on here won't have the chance to gain practice first).
It would makes sense, but fortunately that spot is this only radiators weakness (short of cooling fin damage). lol
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
crack in top of radiator Mobea S-Series Tech 4 04-14-2010 10:38 AM
Crack in Radiator End Tank cmpcpro S-Series Tech 21 03-16-2010 04:27 PM
Crack in radiator? vip3r87 S-Series Tech 12 12-09-2007 07:09 PM
Crack in 96 SL2 Radiator halofan00 S-Series Tech 9 02-21-2006 09:17 PM
new surge tank cap causes crack in the radiator? geartooth94 S-Series Tech 14 05-01-2005 01:59 PM
