Old 10-19-2010, 06:18 PM   #1
paulruiter
paulruiter is on a distinguished road
Default Replaced Timing Chain Can Won't Start
We replaced the timing chain in our 1999 SC2 (twin cam) and were very careful not to move the top or botom sprockets. When we tried to start the car after re-assembly, it tried to start, but would not. I check for spark, it was good. Removed two plugs, very dry, so added some gas directly into the engine, again nothing. Waited 5 minutes tried again, weak sign of firing, but nothing. Seems one of the cams is off, but not sure. I'm very good with small block chevy's and pontiac's, but this is the first real work done on a saturn.
Please advise
Add to paulruiter's Reputation
Rate the quality of this post and help paulruiter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulruiter is offline   Reply With Quote
Old 10-19-2010, 07:33 PM   #2
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
Default Re: Replaced Timing Chain Can Won't Start
Do the marks line up if cylinder one is at TDC? If you can get cyl 1 to TDC and snap a photo of the sprockets (both cams and the crank), perhaps others can point out which one(s) is/are out of whack?
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 10-19-2010, 07:43 PM   #3
SLCraig
Were you replacing for preventative reasons, or did the timing chain break?
As long as you lined up the marks, it should be fine...
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-19-2010, 08:18 PM   #4
paulruiter
Preventative measure
Timing Chain? Chain loose, engine cranks, no start DJboozeAlot S-Series Tech 18 10-21-2012 02:23 PM
Just replaced timing chain... doesn't sound good... kingkevin8 S-Series Tech 12 02-27-2009 01:40 AM
timing chain replaced alleycat S-Series General 22 12-03-2005 12:12 AM
When should 1993 SL2 timing chain be replaced? slickdonkey S-Series General 2 01-31-2005 06:49 PM
replaced timing chain- still noisy GregK Miscellaneous Tech 5 02-27-2001 11:57 PM
