Old 10-13-2010, 12:33 PM   #1
pimpin88
pimpin88 is on a distinguished road
1996 SL
Default 96 head on an 01 block
I'm prepping an engine for my 1996 Saturn SL. It is a SOHC out of a 2001 SL1.
My question is, can I leave the 2001 block as is, with the pistons, crank, etc., basically all of the internals, and put a 1996 head on it? If I do this, can I use the timing chain for a 1996?
Thanks!
Add to pimpin88's Reputation
Rate the quality of this post and help pimpin88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pimpin88 is offline   Reply With Quote
Old 10-13-2010, 01:16 PM   #2
Default Re: 96 head on an 01 block
I could be mistaken, but I thought I had read that mid-99 to 02 used a narrower head than earlier engines.
Old 10-13-2010, 01:18 PM   #3
Dunno what's different but rockauto.com has 2 different Cloyes part numbers for '96 and '01 SOHC's.
The '96 set works '95-'98. The '01 set works '99-'01.
Wait, I dunno WTF is going on but checking for '94 has only a CLEVITE set that works either '93-'99 (SC & SW) or '91-'99 (SL). Part number checking is now suspect...
Old 10-13-2010, 01:19 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Thats for the DOHC's.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-13-2010, 08:22 PM   #5
pimpin88
1996 SL
I'm going to assume I use the 1996 timing chain set since the blocks are interchangeable and I will be using the 1996 SOHC head.
I guess the real question is, will I have any issues using the 2001 SOHC pistons with a 1996 SOHC head? I couldn't find any information on that.
Thanks!
'96 head on '99 block? cuff S-Series Tech 5 08-05-2008 01:08 PM
92-93 block 97 head? netsniper S-Series Tech 9 05-15-2007 01:13 PM
2nd gen head, 3rd gen block remedys S-Series Mods 2 06-04-2006 12:45 PM
can you put a 2.4 block on a 2.2 head jhutch2115 Ion General 3 07-28-2005 02:50 AM
99 block with 92 head elvinrodr Mods and Performance 6 01-28-2004 09:56 PM
