Old 02-19-2010, 03:30 PM   #1
deacon20
deacon20 is on a distinguished road
Default Coolant Issue
My coolant light flashed on and off and the coolant level looked low so I added coolant and now the car gets into the red in a hurry and is overheating. Previous to adding coolant I did not have any issues. Any suggestions?
Add to deacon20's Reputation
Rate the quality of this post and help deacon20 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
deacon20 is offline   Reply With Quote
Old 02-19-2010, 03:32 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: Coolant Issue
Year/Make/Model of your car?
sounds like it could either be the water pump going sour, or the infamous chocolate milkshake in the coolant.
In any case, get a pressure or UV test done on your car.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 02-19-2010, 03:36 PM   #3
deacon20
It is a 99 Saturn SL2. Thanks for the help. The coolant I added is about 2 years old. Could that be a factor?
Old 02-19-2010, 03:40 PM   #4
adventureoflink
I dunno... usually coolant is good for up to five years (dunno about shelf life though).
Elephant in the room: you DID make sure your serpentine belt is on nice and tight, without any cracks in it, right? without the S-belt, the engine will overheat quickly (in about three minutes or so) due to the water pump not turning.
Also, when was the last time you flushed your coolant? (Redundant I know, since you're losing coolant somehow, so yeah still get a pressure or UV test done. Somehow I still suspect the water pump is going bad though.)
Also, you should replace the ECTS if you haven't done so (although even if everything besides this sensor was working, it wouldn't overheat quickly). Instructions are in the how-to library.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 02-19-2010, 04:43 PM   #5
deacon20
Thanks for the help. Probably been 50,000 miles since coolant was flushed. My fault on that one. Will look into the water pump and belt issues.
Old 02-20-2010, 02:06 AM   #6
Signmaster
It would be a good idea to get the car up to temp and look for any leaks. The coolant is low for a reason.
If the water pump is going that will cause excess heat, and if the thermostat is going or gone that could cause the same. The excess heat will often cause a leak due to the higher pressures of that heat.
Check the upper part of the radiator inlet side below the hose really well when it's hot. The radiators are subject to cracking in that area.
Coolant issue tempomental S-Series Tech 26 02-12-2010 05:13 PM
Another Coolant Issue Matt4572 S-Series Tech 2 12-30-2009 04:18 PM
2000 LS2 Coolant Issue batmanT L-Series General 6 11-26-2009 10:56 AM
Coolant Loss Issue Krusen04 S-Series General 3 09-04-2009 11:47 PM
Coolant Issue w/L300 Shadowless L-Series General 1 03-09-2007 06:25 PM
