Old 10-30-2009, 08:02 AM   #1
dlacacres
dlacacres is a glorious beacon of lightdlacacres is a glorious beacon of lightdlacacres is a glorious beacon of lightdlacacres is a glorious beacon of lightdlacacres is a glorious beacon of light
Default S-Series Trans Fluid type???
Hi all,
I just have a quick, easy question. The Owners manual for my 2001 S-Series Wagon says to use "Saturn Transaxle Fluid". It also says "DEXRON III" may be used, but shift feel may be affected and I have to change it every 30, 000miles if I substitute the DEXRON. Is there really any difference???
Add to dlacacres's Reputation
Rate the quality of this post and help dlacacres reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dlacacres is offline   Reply With Quote
Old 10-30-2009, 10:18 AM   #2
Default Re: S-Series Trans Fluid type???
Might be a moot point since, AFAIK, you can't buy Dex III anymore.
I'm assuming you're talking about an automatic transmission the manual transmissions also require Saturn ATF or Dex III.
I've read here that Dexron VI is marginal but acceptable for use in the automatic transmissions. It does have a different (lower) viscosity (at 100C, iirc) than Dex III. Here's some discussion on viscosities
http://www.saturnfans.com/forums/sho...d.php?t=140665 and there is more if you want to search
I don't know how much "Saturn Transaxle Fluid" costs or it's change interval, but given the costs of a transmission, I'd probably go for a good synthetic (I have a manual transmission and went with Mobil 1 as that is what was available) and change the ATF and filter every 30k miles.
This is a How To for changing the ATF and there's another How To in the How To library here.
http://www.saturndan.com/00Sautotrans.pdf
There might even be a video How To on YouTube (by richpin06a). This is a simple DIY for a novice
Old 10-30-2009, 12:31 PM   #3
hholbein
1997 SW2
dlacacres --
I'm not sure how many miles are on your Saturn and whether you plan to keep it a long time. If you do, you might consider changing your existing ATF to a full synthetic ATF like Castrol/BP/Allison's Transynd or Amsoil's ATF.
Transynd costs ~$35/gal at GMC/Allison truck repair depots, is fully DEXIII compatible, and will run for 100K miles in a truck transmission.
I think with a good WIX or OEM filter, you should be good for 100K miles easy, probably longer.
Amsoil ATF is a near clone of Transynd, costs the same or a little more.
Transynd is working well in my Manual Transmission as well.
Add to hholbein's Reputation
Old 10-30-2009, 12:57 PM   #4
Leafy
Leafy is on a distinguished road
Leafy's Avatar
I've been wondering this too since its coming up on 10K since my tranny fluid was changed and this fail-o-matic needs to last till I'm out of college. I was just going to end up putting mobile 1 synthetic in and hoping for the best since you cant get dex III anymore.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 10-30-2009, 05:02 PM   #5
dlacacres
Yes. I do have an automatic and have about 105,000 miles.
Old 10-30-2009, 07:10 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
my Saturn(s) are 5-speed manuals and I can't say that I noticed anything when I went from OE Saturn transaxle fluid to Valvoline Dexron III ATF.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-31-2009, 12:10 AM   #7
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
I've been using Castrol synthetic dextron IV. It's about $7/quart at the auto parts store.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 10-31-2009, 12:15 PM   #8
Frankd1
Frankd1 is on a distinguished road
1998 SL1
I have Mobil 1 ATF in mine, seems good!
Add to Frankd1's Reputation
Rate the quality of this post and help Frankd1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frankd1 is offline   Reply With Quote
ATF Fluid Type 97sl2DOHCaut1.9 S-Series Tech 8 12-28-2009 06:24 PM
Overfilled trans Fluid, now TC not lockout. Is Total trans rebuild ahead? 62morgan S-Series Tech 14 02-23-2009 09:30 AM
What type transmission fluid? Forrest Vue Tech 4 07-17-2008 05:01 PM
Type of tranny fluid for 97 SL2 Pioneer_Saturn S-Series General 5 04-03-2008 12:24 AM
Using synthetic trans fluid, how many miles till the next fluid change? turbobuick33 S-Series Tech 11 06-14-2007 02:06 PM
